Lenny sent me the contract that Don Currie drew up with his comments on items that didn't meet contract requirements.What makes our 2012 Anti Crime Roadster the The Best of it's kind?...check out the details and watch as we build this incredible car!
It looks like an Anti Crime Roadster should.
It is aesthetically and dimensionally correct.----- Not Bob Butts body as claimed by builder
It is sure- footed and reliable, powerful and very fun to drive.---- Broken down numerous times and hood blew off
Based on our new exquisitely detailed gorgeous Triple Black Urethane Gen 3 bodyshell this example sports the latest in ACR gadgetry and effects that are a physical and visual retinal delight. ,---- Body panels wavy and fiberglass cracking and paint bubbling Hood blowing off was the retinal delight, Not
The Fittings:
An all new SUPERCHARGED Drivetrain on a all new modern tubular steel frame with polished control arms,----- Not supercharged
Aldan adjustable poly bushed coil-over shock absorbers with urethane bushed mounts and sculptured towers.
4 Wheel disc brakes, 4 Bar rear suspension with Strange rear axle and gear ratio of your choice. ---- Bolt fell out and brakes locked up
Rugged Sway bar etc. This chassis provides you with excellent vehicle control, as well as a superb, comfortable ride under a wide range of road conditions which takes our Anti Crime Roadster down the track and around the slalom course into the 21st Century and beyond! ----Was told that this was a show car only and to be trailered
Maserati radiator with twin electric fans and custom surge tanks--- Standard aluminum radiator, no surge tank & one small fan that overheats
C 6 automatic transmission---- Used C4 transmission
Dual exhaust with chrome tips
20 gallon fuel tank---- 12 gallon fuel tank
A detailed full frame and suspension
15x7 and 15x10 Radir polished aluminum rims with new tires.---- Miss matched tires
ACR spinners
Triple chrome plated rear 'rocket pipes'
Rear Stainless Steel ' Turbine' with functional flame via electric solenoid--- doesn’t work and never did
ACR parachutes---- Cheap plastic cover with foam blocks no parachute at all or pull rings, paid for
Correct style 18 gauge steel grilles with edge molding
Custom fitted deep set rear tailight lenses--- that don’t work
Rear camera--- Never installed, paid for
Front 7" Halogen headlights
Front amber signal lenses---- Installed don’t work
ACR 'Chaincutter' (retractable)---- never installed paid for
Power operated hood and trunk---- never installed, paid for
Fully painted inner hood liner with ACR symbol ( a UMC exclusive) with light--- hood flew off & was never lighted
New Steel inner fenders, Steel firewall
Steel trunk floor, Steel wheel tubs and multi steel tubular subframe throughout
Twin batteries----one used battery
18 circuit wire harness
Correct style carbon fiber wrapped 'Rollbar'---- not carbon fiber
Billet polished aluminum beacon housing and fitted rotating red light
Twin Rollbar ' Antennas' with red top lighted lenses---- mismatched lenses are not lighted
Rear 3rd brake light--- Never installed, paid for
Front and rear Lexan canopys set in wraparound steel chrome plated canopy frames---- Bent L trim gaps in fitting and doesn’t fit roll bar properly
Billet Aluminum custom made ACR steering wheel with Billet hub and signal buttons inset
Tilt steering
Five piece rolltop aluminum dash and under dash panel trim plate---- Never installed, paid for
Steel center console with courtesy lights and aluminum top plate and trim---- No courtesy lights
Billet aluminum Hurst Pistol grip shifter---- Never installed but paid for
All ACR dash plaques, ACR button switches--- Removed plaque
ACR turn ' T ' lever
Parachute 'pull rings'---- Never installed but paid for
Fire extinguisher---- Not installed don’t care
Seven piece Autometer gauge package---- Installed but not hooked up no lights eaither
Multiple toggle switches to control:
Headlights, beacon light, chaincutter, ACR phone, ACR beam antenna, roll bar arch lights---- Chain cutter not installed paid for
detecta scope, alarm, flamethrower, ACR lights, heater, defrost, 2 speed fan switch. ----Alarm not installed, Flamthrower doesn’t work, heater, defrost, 2 speed fan switch never installed but paid for
Seven inch DVD player---- Never installed but paid for
Double Din CD player with massive Sony amplifier and Boom Boxes---- Never installed but paid for
Alarm---- Never installed paid for
Heater-Defrost---- Never installed paid for
Detecta Scope
ACR compass with multiple dash light display---- Never installed paid for
ACR Phone lighted (prop)---- Is not lighted
Chrome plated door jam sill plates
Fully upholstered interior with rear seat storage compartment carpeted (seperated from trunk compartment)
Leather upholstered black bucket seats with embroidered ACR emblem ( a UMC first) , fully adjustable for even the tallest drivers---- Seats not bolted to floor boards
Seat belts
Carpeted trunk floor and trunk lid light---- Not installed and not lighted
Electric solenoid operated door releases with Billet handle levers for manual release with remote key fob---- Installed doesn’t work at all
Aluminum door panel accents match aluminum dash trim
Rear deck ribbed panel with wraparound aluminum trim and stainless steel vents---- Not correct to Batmobile steel siding installed
