Posted 5/4/2006 3:26:26 PM |
Visits: 421
Now I got it. I'm obtuse. All of the replicas - six flags, Batgod's, Jacks, N8's, Kevins, Rusty's, even Carmel and the Sweede's have the lights centered. So they all came from the cars that were commissioned for Six Flags. Hmmm. I wonder about the car they gave away after returns - if it was off the original or the 6F body? SO Kevin... are you going to make those wider before you pull a mold? You could be the only one selling a "wide-body" N8, you added spacers to get the weheels out that far in the first place right? So have youu fgured out how much extra fender you need to add to get over the tire?
_______________________________________________ When I die, I want to die like my grandfather, who died peacefully in his sleep. Not screaming like all the passengers in his car.
Posted 5/4/2006 5:50:35 PM |
Kevin......Tilt? Not!! I called Amos today and what he said is the Car Tilts...not the body. Sorry but I told you so. Like I said you actuate the switch which inturn lifts the front end by the hydraulics in the front suspension ("Tilting" the car) to give access to the engine through the wheelwell opening. Yes he did change the carb by climbing in and removing the air cleaner and then the carb. He said it was a pain. You can see the new carb here and also see the hydraulic actuator in this picture. He also said to access the engine that you removed the bolts at the firewall and around the bottom of the body. Then you remove the entire front clip. Sorry Kevin but I told you so. 2 piece body and no tilt body. ha ha told you so...
Posted 5/4/2006 6:07:11 PM |
Visits: 4,045
Jesus thats a tight fit. I suppose i never took working on the engine after it's built into consideration.
Posted 5/4/2006 6:08:53 PM |
Visits: 421
Here Jack: Click: Haha
Posted 5/4/2006 6:27:00 PM |
Visits: 4,045
(to go wit the Nelson laugh)
Posted 5/4/2006 6:30:17 PM |
Wait I have another war to start. Tim are you saying that Dave's 1/18th is all wrong?
Posted 5/4/2006 6:47:47 PM |
Visits: 4,045
Uh Oh...
Posted 5/4/2006 10:43:17 PM |
Posted 5/5/2006 2:05:50 AM |
Visits: 4,625
Well then, crisis averted!
Posted 5/5/2006 6:32:06 AM |
Dang I tried.
