Jet exhaust
12345»»»
Jet exhaust Expand / Collapse
Posted 8/29/2006 12:37:11 PM
If anyone has any dimensions for the exhaust/turkey feather assembly, I'd like to see them.  The only dimension I have is for a turkey feather.  Not sure if they are accurate though so I'm open to those as well.  I'm working on Jacks "umbrella" idea...
Post #53856
Posted 8/29/2006 2:06:00 PM
WOW Tim! Those files look great!!!
Post #53859
Posted 8/29/2006 2:47:17 PM
Last Login: 4/23/2024 5:59:38 PM
Posts: 2,343, Visits: 8,997
Mine are very close to yours, I think the large end is a little big on yours. But I could be wrong. I blew up the 1/18 th scale to get these numbers.
Post #53864
Posted 8/29/2006 3:27:04 PM
Posts: 815, Visits: 3,239
They do look good. Are you using autocad?
Post #53866
Posted 8/29/2006 3:30:56 PM
Yeah, that's pretty close, thanks...
I'm kind of just figureing this out as I go.  Once I get enough pieces in place I can modify them to work properly....
Post #53867
Posted 8/29/2006 3:31:24 PM
No, SolidWorks...
Post #53868
Posted 8/29/2006 5:57:48 PM
Looks like it's going to work!  I can slide the small ring in and out and the two feathers with rods attached to them open and close perfectly.  I can't wait to hook up the rest of the parts...
Post #53869
Posted 8/29/2006 6:00:53 PM
Here it is pushed open (beyond where you would want)
Post #53870
Posted 8/29/2006 6:38:11 PM
Jack, do you like pictures?
Post #53871
Posted 8/29/2006 6:55:54 PM
Tim, YES!  I love it.  This is one of the coolest threads ever.  You should even be able to figure out what size actuator to use to.  Probably a very small one would work, say a 1" actuator.  But yeah again this is awesome!!
Post #53872
12345»»»
All times are GMT -5:00, Time now is 8:55pm
Execution: 0.188. 10 queries. Compression Disabled.
