Posted 8/29/2006 12:37:11 PM |
If anyone has any dimensions for the exhaust/turkey feather assembly, I'd like to see them. The only dimension I have is for a turkey feather. Not sure if they are accurate though so I'm open to those as well. I'm working on Jacks "umbrella" idea... ![](http://cltc.co/Images/Uploads/Images/a81b4b43-b861-4148-911d-4a24.jpg)
![](http://cltc.co/Images/Uploads/Images/8d7e6ad7-2ba1-452d-9e06-a852.jpg)
Posted 8/29/2006 2:06:00 PM |
Visits: 4,625
WOW Tim! Those files look great!!!
Posted 8/29/2006 2:47:17 PM |
Last Login: 5/16/2024 2:01:35 PM
Visits: 8,999
Mine are very close to yours, I think the large end is a little big on yours. But I could be wrong. I blew up the 1/18 th scale to get these numbers. ![](http://cltc.co/Images/Uploads/Images/7398a821-332a-4ac8-b9c1-1653.JPG)
![](http://cltc.co/Images/Uploads/Images/bf9cab64-ef0b-4142-b4ec-3ce6.jpg)
Posted 8/29/2006 3:27:04 PM |
Visits: 3,239
They do look good. Are you using autocad?
![Smoke](http://www.chickslovethecar.com/board/Skins/CLTC20/Images/EmotIcons/smoke.gif)
Posted 8/29/2006 3:30:56 PM |
Yeah, that's pretty close, thanks... I'm kind of just figureing this out as I go. Once I get enough pieces in place I can modify them to work properly.... ![](http://cltc.co/Images/Uploads/Images/b305c5c1-6704-439e-b76d-ba8a.jpg)
Posted 8/29/2006 3:31:24 PM |
Posted 8/29/2006 5:57:48 PM |
Looks like it's going to work! I can slide the small ring in and out and the two feathers with rods attached to them open and close perfectly. I can't wait to hook up the rest of the parts... ![](http://cltc.co/Images/Uploads/Images/69c01e53-9c03-4b03-9fdb-3d86.jpg)
Posted 8/29/2006 6:00:53 PM |
Here it is pushed open (beyond where you would want) ![](http://cltc.co/Images/Uploads/Images/150071e1-8c79-4c50-93c4-65fc.jpg)
Posted 8/29/2006 6:38:11 PM |
Jack, do you like pictures? ![](http://cltc.co/Images/Uploads/Images/87860943-9f61-4cad-bfca-2243.jpg)
![](http://cltc.co/Images/Uploads/Images/6b731b14-cb70-4dba-b749-593f.jpg)
![](http://cltc.co/Images/Uploads/Images/cec8562a-fc2a-4904-9921-85be.jpg)
Posted 8/29/2006 6:55:54 PM |
Tim, YES! I love it. This is one of the coolest threads ever. You should even be able to figure out what size actuator to use to. Probably a very small one would work, say a 1" actuator. But yeah again this is awesome!!
