Posted 8/30/2006 8:21:07 PM |
Visits: 4,625
W-O-W. That is some incredible work, Tim. AMAZING! Ok - so who wants to tackle this project???? Hell, tell me how it all goes together and I will build one! How do you hinge the feathers?
Posted 8/30/2006 8:22:35 PM |
Visits: 4,625
Now - what about shortening each of the arms levers and widening the center ring... Then instead of a steel or aluminum rod in the center, you use a hollow tube that you can route the propane through for the flame? Thoughts?
Posted 8/31/2006 2:35:41 PM |
Visits: 4,045
Can u imagine driving behind that thing and seeing it open. U'd shite yourself. "Jaysus Peggy get off the road. It's gonna erupt"
Posted 8/31/2006 3:06:49 PM |
Visits: 3,239
That's a good idea Justin. It should be easy to mount the rods to a ring to go around the end of the flame system.
Posted 8/31/2006 3:30:47 PM |
You'll get less movement by shortening the rods but they probably could be shortened some. If I knew more about the flamer then I could design around it. How big of a hole would it require?
Posted 8/31/2006 3:51:00 PM |
Visits: 4,625
I am thinking half inch, but what do I know? Just enough for the propane line to run through, then the thing can flare out at the end to spit massive flames. Nate?
Posted 8/31/2006 4:25:42 PM |
The hole is already 1" in diameter, just need to use a hollow tube.
Posted 8/31/2006 4:34:40 PM |
Visits: 4,625
Wow! I think that will be more than sufficient!
Posted 9/1/2006 11:03:45 PM |
I enlaarge the hole to 2" and made the tube hollow. I wish I knew what a flame thrower required.
Posted 9/1/2006 11:18:11 PM |
Visits: 7,280
