Dustin's Tumbler build
12345»»»
Dustin's Tumbler build Expand / Collapse
Posted 3/25/2015 8:40:23 PM
Last Login: 7/15/2022 10:36:12 AM
Posts: 37, Visits: 116
Hey guys, Dustin here. I started my tumbler build finally, but it's a little slow going as the only chance I have to work on it is while my 11 month old son is taking his naps. Busy busy busy... Anyways, as you can see, I finally got some welding done. It's day 8 of actual build work but this has been in the research and planning stages for about a year now.
"Were it so easy." -Arbiter
Post #137463
Posted 3/25/2015 9:08:17 PM
Hey Fedicane,
Looking great. Welcome to the forum and good luck on your Tumbler building.
Post #137464
Posted 3/26/2015 7:30:42 PM
Posts: 663, Visits: 3,900
New build? Awesome!
CLTC Exclusives
Favorite Galleries
Returns Batmobile
Keith Shorts Sculpture
Kevin's Batmobile Gallery
Doug Hines' Batmobile Gallery
Jack's Batmobile Gallery
Rusty's Batmobile Gallery
Animated Batmobile Gallery
Sweden Batmobile Gallery
Carmel Batmobile Gallery
Post #137468
Posted 3/27/2015 11:37:18 PM
Alright, day 10 of work. But day 11 will have to wait till my new mig comes in. Hopefully, no more than a week.
Got the first of four panels of sheet metal, for the under side plating/floor board, welded on and plug welded in place. The one on the right is about a quarter welded when my mig crapped out.
Post #137472
Posted 3/31/2015 1:23:27 PM
Got a small TIG to get me back on track on my build till my new MIG gets here. TIG is good but slooooooooooow.
Post #137495
Posted 4/12/2015 11:27:43 AM
Been a while since my last update. So far, I've only been able to finish welding the bottom of the frame and apply some filler in preparation to painting, due mostly because of the FedEx screw up with sending my new mig.... Oh well. At least I'm back on track...
Post #140535
Posted 5/8/2015 8:32:26 PM
These are the bottom of the frame all primed and painted with a couple layers of truck bed liner
Post #142571
Posted 5/8/2015 8:36:41 PM
Here is the primary weight frame mostly welded. Unfortunately, it's sat like this for about a week now because I have been working on the truck that is the future donor vehicle for this build.
Post #142572
Posted 5/27/2015 2:38:26 PM
Been working on the engine as of late. But, it's coming together. Thought I would have some fun painting it.
Post #143614
Posted 6/18/2015 7:44:53 AM
I'm starting to build the front wheel supports (arms?). Considering the torsional stresses that will be on the arm due to the wheel attached not being on an axle for support, should 1/8" wall thickness on the rectangle tube steel be sufficient to handle the stress? Or should I move up to 1/4"? I know 1/4" will definitely work but it will also add considerably more weight to my build.
Post #147680
12345»»»
All times are GMT -5:00, Time now is 9:51pm
Execution: 0.140. 8 queries. Compression Disabled.
