Posted 3/8/2014 3:06:02 AM |
Visits: 8,329
Front wheel tac welded on.
Compare the angles of turn. Looks pretty close.
Posted 3/10/2014 1:51:14 PM |
Hey spidey4fun, What kind of motor is that in your last photo? How many horsepower? vertigo
Posted 3/11/2014 2:26:55 AM |
Visits: 8,329
13.5HP or 10KW
Posted 3/12/2014 3:19:28 AM |
Visits: 8,329
Turned my first thread on a lathe... happy camper here!!
Posted 3/31/2014 4:00:20 PM |
Visits: 8,329
I've a buddy doing the welding. Thought it best I get a professional do the bits you dont want failing.
Posted 3/31/2014 4:01:13 PM |
Visits: 8,329
Master brake cylinder looks about right.
Posted 4/1/2014 9:25:14 PM |
Visits: 8,329
Im currently getting some more of the frame cut, so thought I'd start the steering bearing housing.
I turned down some steel to make a bearing housing. Bob D mentioned in one of his posts a 5k lathe isn't necessary when building a tumbler, but it sure does make the creation process a lot more fun when you're making your own parts.
Also starting on the frame bracing. Just needed a 16mm bit to drill out the hole for the bolt.. Thanks Mr Ebay!! it's on the way.
Next Ill start on the support rod that mounts under the spring.
Posted 4/3/2014 2:55:33 AM |
Visits: 8,329
Some welding by a buddy of mine... I'm sure glad he offered to help out.
Posted 4/3/2014 7:36:15 AM |
This is by far, the worst 1989 batmobile build ever. It looks nothing like it!
Great job spidey, the parts are coming out beautifully!
Posted 4/3/2014 8:12:30 PM |
Visits: 8,329
