Posted 8/12/2012 8:51:00 PM |
Last Login: 6/21/2015 6:09:39 PM
Visits: 534
mines front pipes are one
and nismo intercooler
reo bar back on
bumper back on still need to trim one of the n1 vents
bonnet is on aswell
If you make yourself more than just a man, if you devote yourself to an ideal... you become something else entirely. A legend, Mr. Wayne, a legend
Posted 8/20/2012 9:47:21 PM |
Visits: 534
ballstic cat all done
drilled and welded on sensor bosses at work one in front for exhuast temp
and the rear one is for cat over temp warning
all fitted now but forgot to get pictures
picked up dash 12 fittings and black braid hose from earls today
making up the lines
all done
next up was to fit the exhaust shield i made and finish the intake piping
Posted 9/26/2012 1:16:30 AM |
Visits: 534
small update
mines speedo
and just becasue
p.s moving a fully weighted gtr on your own is not fun
Posted 11/20/2012 6:31:20 PM |
Visits: 534
the final tune has been done, full boost is set, cams gears adjusted
Posted 11/22/2012 9:51:55 PM |
Nice looking chart
I just finished assembling my fully built EJ257 for my subaru.. I need to go to a speed density tune in the spring. The bigger turbo is out running my MAF setup. Right now the car is hitting 340whp but power drops off the table at 4500rpm. The car bogs down, pulls timing because the MAF thinks it's maxed out.
I'll be doing a bunch of polishing of the aluminum and stainless pieces in the spring and doing some final tidying up of the engine bay. With the speed density setup, I'll likely run the air filter right off the compressor housing
Posted 11/29/2012 1:49:48 AM |
Visits: 534
brcewane (11/22/2012)
Nice looking chart
thanks
i spent a lot of time trying to get as much response out of the 2.6l
the big thing was the cams and head work, i think the best thing about it was when my tuner gave it back to me he said if i was building an all round car that's the setup id want.
the ej looks nice i did a fair bit of for a friend who had my99 wrx ended up wiring in a z32 AFM but even with your power it will max that out might be time to MAP setup.
Posted 1/12/2013 9:58:44 PM |
Visits: 534
so i was able to get out to a motorkhana event
not the best event to test a gtr on but none the less a nice low stress just to give the car a shake down
lots of interest in the car
getting ready to start the day
staging
power under steer all day long
and then it happened
decided to spill its coolant in the staging line. power fc got up 96 degrees C and defi gauge from the bottom rad was showing 102 degress C
leak is coming from under the plenum somewhere. once it cooled down it took about 2l of water and the leak had turned into a drip.
decided to trailer it home to be safe
looks like the plenum will have to come off unless i can find the leak on the hoist
Posted 1/15/2013 1:15:24 AM |
That sucks. But amazing log nonetheless.
Posted 1/23/2013 3:57:48 AM |
Visits: 534
thanks Doo Hee
at least it happened with people around and not on the highway where it might of gone unnoticed till it was too late
Posted 1/23/2013 4:00:30 AM |
Visits: 534
since blowing the water hose under the plenum at motorkhana
this water hose has caused some major headaches for me mainly from this
tomei metal gaskets and all new water hoses from nissan
getting the car up on the hoist to check to the leak
hook up the pressure tester
no luck finding it, so time to pull the plenum off. *insert swearing of your choice as it was all covered*
several hours later its off
again hook up the pressure tester
and there she is
replace the hose and while the plenum is off start on the replacement water hose for around the head
re fill rad and pressure test it
held pressure for an hour so time to reassemble
while i had it on the hoist i fitted the correct no colour coded lower lip and ARC wings
time to test
we have a hiss *more swearing*
take plenum off round 2
replace plenum
hiss remains
test with carbie cleaner hiss goes idle still low
replace plenum round 3
this time new gaskets, and intake runner gaskets, idle control valve, new o rings for balance pipe
find carbie cleaner outside of o rings in balance pipe
refit his is gone, but idle still crap
aac adjustment makes no difference. *more swearing*
after a long chat with the tuner we put it down to the aac being clogged
so i remove it to give it a clean and you would believe what i found ween trying to put carby cleaner down the air hose
oh yes a lead sinker jammed in there
replace hose and idle is finally adjustable
on the rollers for a once over
engine is a bit more free reving and pulled 349rwkw on the first two power runs. but was leaning out a little.
bit of a clean up in tune and it ran exactly the same power run of 333.4rwkw as when it was first tuned
