Posted 6/7/2012 6:22:20 PM |
Last Login: 6/21/2015 6:09:39 PM
Visits: 534
abs, brake lines and and powersteerin resivour are in
you can see the body colour brake stopper
new washer bottle
cleaned up the bov pipe (gaurd ***** is back in aswell)
gaurd, head light, and indicator all back in
oil cooler and hard pipe installed, you can see where i mounted the horns so they are hidden
close up of horns, you can see the custom braket i made out of alloy
dynamat rear firewall back in
power fc hand controller mounted
still need to work out the wiring and how to mount the relays
If you make yourself more than just a man, if you devote yourself to an ideal... you become something else entirely. A legend, Mr. Wayne, a legend
Posted 6/14/2012 7:29:06 AM |
Visits: 534
more wiring
marked out the pins on the stock computer and old loom for the AFK and EVC.
can see here some time in its previous life it had something tapped into the tacho signal
onto more simply things for my brain, radiator mock up
nismo rad next to the stocker
as you can se the lower inlet has moved to the left and the water temp has moved to the top to make way for the rad drain tap
close up of changes
test fit with shroud on, tire shine made the plastic come up like new
looking good
all finished and ready for the engine
Posted 6/15/2012 7:18:48 PM |
Visits: 3,119
Wow this is looking great ....well done..makes me want to do the inside as well as the outside but probably not in my budget....
How much thought and planning have you put into this? are you doing most of the work yourself ?
doesn't look like you're going ummm lets do brakes today.
I wish I had your focus ,
best of luck
cheers dude..
later
333 HALF EVIL
Posted 6/19/2012 7:06:49 AM |
Visits: 534
Unholy (6/15/2012) Wow this is looking great ....well done..makes me want to do the inside as well as the outside but probably not in my budget....
best of luck
cheers dude..
later
thanks mate
i planned the build for about 2-3 years at the same time i started collecting parts. so it was very well planned out and everything was ready when it cae to start working.
other then the actual engine assembly ive done all the work
Posted 6/20/2012 8:59:13 PM |
Visits: 534
new seats just arrived
got the passanger seat for a trieal fit/run and i was excited
i got in the engine bay to touch up the flare nuts with some paint when i found this
brake stopper out
lots of water later
and its out
time for a new one from nissan might even get a clutch master as well just to be safe
Posted 7/3/2012 8:11:05 PM |
Visits: 534
more wiring
burnout head light switch, extra wiring looms i found behind the headlights suggest a HID kit had been fitted in a past life causing this
replacement from a wreckes crimped and ready to go
modified my defi warning light so the wire comes out the base not the back to hide the wires. you can see where the plug was on the PC board and where i re soldered it
all fitted and done also fitted N1 haved light switch and deleted radio button switch
interior refitted
Posted 7/5/2012 1:17:00 AM |
Visits: 534
parts from nissan arrived
brake master from r34 gtr
new clutch master
firewall insulation, specially made for me by nissan japan took 6 weeks
all went in with no problems except for one small thing
Low level warning plug/wiring is diffrent from r32 to r34
this just arrived aswell
Posted 7/15/2012 6:53:03 PM |
Visits: 534
no explination needed
Posted 7/19/2012 11:36:53 PM |
Last Login: 8/26/2014 7:04:30 PM
Visits: 61
Awesome job so far bud! Wish we could of got that car here in the united states. R34 would of been one i would love to own.
Post more pics when you can.
:Alamo City Comic Con
http://www.alamocitycomiccon.com/
Posted 8/8/2012 8:34:20 PM |
Visits: 534
