Last Login: 2/25/2019 7:28:34 PM
Visits: 428
I got the throttle quadrant in a couple of weeks ago.. Morphing a Quicksilver ratchet shifter to the underside to work with the tranny.
Visits: 428
All right, last year I had saved a stock big block and a decent twin turbo set up for another project, that I realized might be nice for this project. I got a offer that I thought was bigger than any future need for the stuff. MY MISTAKE; I'll find another.
On the other hand I HAD kept a steering wheel that is a perfect 89 match. It was a new wheel identical to the one that Nitro has posted. One of my guys at the shop had it mistaken for another wheel, and put it on a client's car. When I went to look for it, he told me the story. I called my client, but he had already sold the car (some time ago).
I NEED some help finding another wheel. Any ideas? I can't even tell you the original manufactuer, but I know the wheel.
-Rod
Last Login: 9/27/2007 4:10:38 AM
Visits: 1,452
hay rod, look like itll be a nice build when done, i sent you a pm about it to see if you can help me, cheers
Last Login: 10/21/2019 6:08:24 PM
Visits: 12,736
Nate has the correct wheel. Mountney British GT but I think it is 13 inch not 12. Nice quadrant there is really no need for modification you can run a cable or rod linkage to that baby just fine.
Visits: 428
Kiwibat,
Sorry, For some reason Ican't get access to it... maybe I'm doing it wrong.
-Rod
Visits: 428
Nitro,
Thanks for the good info. After looking at it, you're right; I will probably use the B&M cable. Thank you again.
-Rod
Visits: 1,452
computors are great things at times, i wonted to ask about the body your got or yet to get as to where or who i can talk to about, thats why i did a pm as i didnt think you would post it for all to see, you can pm me as others have without a problem cheers
Visits: 428
You're right Nitro.... It was Nate's, but I appreciate the help. Remembering it was a V-8 TR6 converion that we had and I kept the wheel after we mis-ordered the polished instead of black. Realized that it was the 89's wheel. THANK YOU AGAIN!!
Visits: 1,452
bump  out of interest where did the pic of the car come from? looks great and who do i speek to about the cost of it and what did you get with it? look forward to your reply
Visits: 428
Nitro, I ordered the wheel yesterday. I will worry about the hub when I get the column in. The cap (cover) is something I'll have to sit on the lathe with. I can probably make a few if anyone needs one. Also, I will need to see if you'll part with a bat or two. -Rod
