Posted 11/11/2005 1:29:33 AM |
Visits: 4,625
Polystyrene will melt right away, but polyurethane works like a champ. More expensive, but it saves a step and some work on your part.
Posted 11/11/2005 8:44:06 AM |
Last Login: 11/28/2018 6:56:13 PM
Visits: 1,758
my wife said that would be cute.
i'm not going for cute.
im going for ominous, sinister, menacing, etc.
Posted 11/11/2005 9:32:19 AM |
I thught this thread was about the 89 Headlights? My mistake.
Posted 11/11/2005 10:44:38 AM |
Useless Forum Member
Last Login: 8/18/2013 12:16:26 AM
Visits: 1,909
Here's a donor car for you. It already has the jet engine installed!
Live life to the Max!
Posted 11/11/2005 11:37:45 AM |
All my posts are about headlights...
Posted 12/7/2005 12:33:26 PM |
Visits: 4,045
These are 2 honda civics.
This 1 is an 88 civic and the headlights are very close
This is an 87 Civic and the lights are way off
I'm thinking the 88 civic lights.
Posted 12/7/2005 1:14:40 PM |
HAWK
Last Login: 12/8/2018 12:33:07 PM
Visits: 1,294
Just a thought, polystyrene foam ( Amofoam- from home depot works if you shellac it after you initially sand and form it to the shape desired, then you apply a coat of Bondo and finish the part off. I believe after that if you want to make a plug or copy the shape with fiberglass ,the polystyrene foam which is covered with shellac and bondo will not melt.But you have to go with shellac/bondo/ then fiberglass. The shellac helps the bondo bond to the foam and also creates a barrier of protection.This is the way I Fabricated alot of parts,ex: Side skirts and running boards for an 87 5.0 stang.
Posted 12/7/2005 1:16:31 PM |
HAWK
Visits: 1,294
And yes urethane foam is mad expensive for either the panels or the two part pour it yourself mixture.
Posted 12/7/2005 1:40:47 PM |
I've never tried the shellac but I have used Kilz paint. It's a stain barrier primer. I'll try the shellac next time.
Posted 12/7/2005 1:49:37 PM |
HAWK
Visits: 1,294
cool and I've never tried kiltz, but will give it a try ...where do I get that stuff at?
