Bvs batmoblie I'm trying to build
«««34567»»»
Bvs batmoblie I'm trying to build Expand / Collapse
Posted 1/11/2023 8:31:44 PM
If you can't acquire a B v S DOJ body, you can always build your own. Very difficult to find a useable body unless your frame and mechanics line up exactly with the movie car, even in a reduced scale.
I asked you before, "Did you use any scale models, 3D STL files, CAD/CAM programs, or photo-images to assist you in planning and/or building your batmobile?" Not being nosey, just inquiring to understand your abilities, methods, and level of technology sophistication and how they might mesh with mine and others research.
I don't know your level of CAD/CAM sophistication or accessibility, but I will give you some info that might help you. I remember you said you 3D printed the main gun, so I assume you have some experience.
(1) A life-sized STL file of the B v S that is amenable to scale reduction and independent area/object skewing is available at Do3D.com. The body/skin can be adjusted and/or modified to fit almost any B v S DOJ framing.
(2) A file of your frame and mechanics can be created and the exterior modified Do3D file super-imposed/transparent over them. Then, adjusted for a proper fitting. Body files can be created from this file, etc...
Post #170653
Posted 1/12/2023 4:52:45 PM
The Do3d file is larger than the real car. I think they went by the inflated stats that were out there before the movie came out.
Is your motor in the rear? I was thinking that I probably could modify it.
At this point we're trying to do engine in the front. Not sure if it will work or not, but that's what we're trying. Whe haven't changed the body at all however. Our rear body will just have an empty space there.
I'm in Hawaii now and won't be back until mid-April. Sorry, I don't have any of that info with me here. You would be welcome to come and see the body if you want this spring. I'm a couple of hours north of St. Louis
Post #170656
Posted 1/12/2023 5:19:14 PM
I did find one measurement on my phone. The width of the interior cabin at the seats is 58".
Post #170657
Posted 1/12/2023 11:17:39 PM
sly
"The Do3d file is larger than the real car. I think they went by the inflated stats that were out there before the movie came out."
hey sly, do you remember by what percentage the Do3d file is larger than the real car?
Post #170659
Posted 1/13/2023 12:12:25 AM
Sorry, I don't.
Post #170660
Posted 1/13/2023 6:53:38 AM
Last Login: 4/7/2024 8:21:03 AM
Posts: 44, Visits: 442
Mine's rigth at 58 also
Post #170661
Posted 1/13/2023 5:05:08 PM
Would love to come up and see the body this Spring greatly appreciate the invitation.
Got the motor installed today everything that's coming along will install break System next week
Post #170662
Posted 1/13/2023 8:25:01 PM
We're at the same scale then. I think I reduced the scale of the Do3d file about 75% to get that size as we are trying to go street legal as well.
Post #170668
Posted 1/13/2023 8:28:40 PM
That's funny I was the one that had Do3-D Do the scale model that is my 3-D printed gun on my hummer that was the 1st item that we did
Post #170669
Posted 1/13/2023 11:24:14 PM
so how much was it reduced? The size of their 3d model is larger than the real car. I think our reduction is something like 85% of the real car.
Post #170670
«««34567»»»
All times are GMT -5:00, Time now is 8:12am
Execution: 0.172. 11 queries. Compression Disabled.
