Posted 7/10/2023 12:29:51 PM |
Last Login: 4/7/2024 8:21:03 AM
Visits: 442
Look so awesome my friend you're doing an awesome job both of You I would love to Talk to You guys about possibly getting a pull from your Mold.. Just freaking awesome
Posted 7/10/2023 1:08:18 PM |
Visits: 845
OkBatman (7/10/2023) Look so awesome my friend you're doing an awesome job both of You I would love to Talk to You guys about possibly getting a pull from your Mold.. Just freaking awesome
I remember seeing your chassis when it was an earlier project where it had got to the point of the supercharged v6 in it... glad you went with the FWD LS setup, as the trans is a little stronger, but you may still need it built to handle the torque load those 400+# each wheel and tire combos will put on the CVs back there. If you post up the dimensions w/ wheelbase and total outside widths we can check to see how well this body would fit around your chassis. Sly can speak more to the bodies, but the plan is to get our two cars formed up, and then I'll have to work with a local FiberGlass guy to make any further pulls, since Sly will be too busy driving the car to make more down the road.
Posted 7/10/2023 5:02:35 PM |
Visits: 442
Yep souped-up the transmission also went with 3/4 ton front full wheel drive axles So basically remove the front full 4w drive and moved it to the rear. I will get you some proper dimensions brother even if it's a little off I can always cut it and reshape it would sure save me so much time and a ton of work to get this thing up and going for the kids.. Also I'm putting together a Plaque to thank everyone who has helped in the construction plus we are a 501 c-3 Charity so if that can help you brother I'm all for it.
Posted 7/11/2023 8:11:44 AM |
Visits: 845
OkBatman (7/10/2023) Yep souped-up the transmission also went with 3/4 ton front full wheel drive axles So basically remove the front full 4w drive and moved it to the rear. I will get you some proper dimensions brother even if it's a little off I can always cut it and reshape it would sure save me so much time and a ton of work to get this thing up and going for the kids.. Also I'm putting together a Plaque to thank everyone who has helped in the construction plus we are a 501 c-3 Charity so if that can help you brother I'm all for it.
Very cool on the updates, definitely a much stronger setup now... I'm sure we can get you sorted out with one, it's just going to be a while.
Posted 7/11/2023 12:50:28 PM |
Great angles on those pics Tman.
Posted 7/17/2023 10:58:34 PM |
Visits: 2,297
WOW guys, taking some nice shape there...
Im sure its been a bit of a mission to get it to that point but well worth it im sure...
Posted 7/24/2023 2:52:53 PM |
Waiting for some fiberglass supplies to arrive so I started milling some more parts. Here's the front Driver's Side wheel cover. My choices of dividing the part for milling weren't the greatest on this one. I'll do it differently on the other side.
Posted 7/25/2023 3:33:33 PM |
Visits: 442
Posted 7/29/2023 6:21:05 AM |
Visits: 2,297
Looking great sly...
Keep it coming man...
Posted 7/31/2023 6:10:44 PM |
Here's a link to a video that we made at THEMAN's shop.
