Posted 12/16/2016 12:56:26 AM |
![Forum Member Forum Member](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Forum Member Forum Member](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Forum Member Forum Member](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Forum Member Forum Member](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Forum Member Forum Member](Skins/CLTC20/Images/RankImages/BlockDisabled.gif) ![Forum Member Forum Member](Skins/CLTC20/Images/RankImages/BlockDisabled.gif) ![Forum Member Forum Member](Skins/CLTC20/Images/RankImages/BlockDisabled.gif)
Visits: 995
A bit more work sorted out some framework on drivers side also frame for gullwing door hopefully should have it on all its wheels next couple of weeks.
Posted 12/30/2016 9:24:13 AM |
Visits: 995
Got front wheels on to car need to get all lined up to create steering arms nose cone and suspension mounts. Is there a specific length for steering arms and levers at front wheel. Can anyone help please.
Posted 12/30/2016 6:06:54 PM |
![Has NO LIFE!! Has NO LIFE!!](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Has NO LIFE!! Has NO LIFE!!](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Has NO LIFE!! Has NO LIFE!!](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Has NO LIFE!! Has NO LIFE!!](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Has NO LIFE!! Has NO LIFE!!](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Has NO LIFE!! Has NO LIFE!!](Skins/CLTC20/Images/RankImages/BlockActive.gif) ![Has NO LIFE!! Has NO LIFE!!](Skins/CLTC20/Images/RankImages/BlockActive.gif)
What did your front axles come from?
Do you plan to add additional bracing brackets to these axles? vertigo
Posted 12/30/2016 6:07:39 PM |
Visits: 3,355
Looks pretty cool. I'm thinking about doing the same thing except with a Hq ute (Aussie car ) for those who aren't Australian. You're a good inspiration
Posted 12/31/2016 1:30:53 AM |
Visits: 995
Yes I plan on bracing up the front axles more however they are mounted on a solid bar. I got the front axle of a 99 jeep cherokee xj. I cut of the axles at the hub and added steel bar that was then cut and welded to fit. I also cut the drive shafts and used cv joints to keep hub bearings together.
Posted 1/5/2017 1:54:12 PM |
Visits: 995
So got some more bracing done tonight will get another run at it tomorrow. The shapes coming now I think any opinions anyone or questions lol.
Posted 1/5/2017 1:58:06 PM |
Visits: 995
Posted 1/6/2017 10:16:25 AM |
![Forum Newbie Forum Newbie](Skins/CLTC20/Images/RankImages/BlockDisabled.gif) ![Forum Newbie Forum Newbie](Skins/CLTC20/Images/RankImages/BlockDisabled.gif) ![Forum Newbie Forum Newbie](Skins/CLTC20/Images/RankImages/BlockDisabled.gif) ![Forum Newbie Forum Newbie](Skins/CLTC20/Images/RankImages/BlockDisabled.gif) ![Forum Newbie Forum Newbie](Skins/CLTC20/Images/RankImages/BlockDisabled.gif) ![Forum Newbie Forum Newbie](Skins/CLTC20/Images/RankImages/BlockDisabled.gif) ![Forum Newbie Forum Newbie](Skins/CLTC20/Images/RankImages/BlockDisabled.gif)
Last Login: 1/6/2017 10:42:44 AM
Visits: 4
I didn't realize you are this far along, can't wait to see it in person.
I am sure you will turn at lot of heads when you take it to Tesco to do your shopping lol.
Posted 1/6/2017 11:53:11 AM |
Visits: 995
So got another rattle at it tonight really starting to fly through the work now.
Posted 1/19/2017 2:22:12 PM |
Visits: 995
Still at it changed rear springs and I think you will agree it's made a big difference
