Adding weatherstrip
12»»
Adding weatherstrip Expand / Collapse
Posted 5/19/2005 10:24:39 AM
Last Login: 5/10/2004 1:36:31 AM
Posts: 671, Visits: 0
A long while back someone asked about adding weatherstrip. Well this is what I can up with and so far it seems to be woring great. Here is what I am working on for the trunk. I also did the canopy area the same way.
Step 1: I roughed up the existing fiberglass and made a mark where I wanted to add the flange. I add a 1" strip of blue installation foam board (Just like what Tim is using on his go-cart((Thanks Tim))). I used double sided padded carpet tape to hole the 1" foam in place. NOTE: I covered the foam in clear packing tape so that it would release from the fiberglass.
Step 2: I used The West System Epoxy fiberglass resin and 3 layers of fiberglass cloth. NOTE: I covered the foam in clear packing tape so that it would release from the fiberglass.
Step 3: I found that it is very easy to trim the fiberglass just before the resin cures. (Still need to do the Bondo work)
Step 4: I found this great weatherstrip at JC Whitney.com . It comes in a 25-foot roll and cost right around $50. Catalog number 143539.
http://www.jcwhitney.com/autoparts/ItemBrowse/c-10101/s-10101/p-100000166883/mediaCode-ZX/appId-100000166883/Pr-p_CATENTRY_ID:100000166883
Step 5: Install the weatherstrip. It goes on with just a push and gives a nice finished look.
Well that's how I'm doing it. Hope it helps.
Post #30719
Posted 5/19/2005 10:25:00 AM
Last Login: 5/10/2004 1:37:34 AM
Posts: 1,034, Visits: 0
That's awesome Jack! I'd sure like to see more posts like this one...
Post #30720
Posted 5/19/2005 10:25:08 AM
Thanks Tim. I too would like to see more post like this (Kevin, Don, Nitro, Mark, etc). Sorry about all of the typos. :confused
Post #30721
Posted 5/19/2005 10:25:15 AM
Last Login: 5/10/2004 1:36:43 AM
Posts: 518, Visits: 0
Cool! Looks great Jack.
Post #30722
Posted 5/19/2005 10:25:26 AM
Last Login: 5/10/2004 1:35:30 AM
Posts: 55, Visits: 0
Cool, I made one of Jack's lists.
Post #30723
Posted 5/19/2005 10:25:38 AM
Nitro, you have been on my "Hit" list for a very long time.
Post #30724
Posted 5/19/2005 10:25:47 AM
We'd like to see some pics though, Nitro.
Nitro... you folks had a very odd sense of humor when they named you.
Post #30725
Posted 5/19/2005 10:26:01 AM
Father ,was a pyromaniac and mother was a hottie!
Post #30726
Posted 5/19/2005 10:26:11 AM
Well Nitro, how about them pictures?
What do you think about the weatherstrip idea?
Post #30727
Posted 5/19/2005 10:26:19 AM
Well if i was ever going to build one of those 89 type cars I would probably steal your idea.
Post #30728
12»»
All times are GMT -5:00, Time now is 7:24am
Execution: 0.359. 8 queries. Compression Disabled.
