Vertigo's Tumbler Build
«««56789»»»
Posted 8/31/2014 9:39:00 PM
Hello Everyone,
Given the hardened 2-inch center axle and no high dollar carbide bits I started stepping out the 5/16-inch piloted holes with HSS 1/2 inch, then 9/16 inch, then 5/8 inch, then 3/4-inch, and finally with a 13/16 inch drill. Completed two holes and almost a third in 8-hours.
Post #108553
Posted 9/1/2014 8:45:59 PM
Hello Everyone,
Finally finished the core axles with axle sheaths for my Tumbler's front suspension arms. vertigo
Post #109562
Posted 9/2/2014 8:37:07 AM
Hello everyone,
A friend stopped by this morning for a visit while I was working on my Tumbler. Where I'm usually found anymore. While looking over my progress he asked me what king of clamps I was using. For anyone else wondering, they are 6" Strong Hand clamps. Once you use the Strong Hand clamp you will never use a regular C-clamp again, unless forced to. Why? You can manipulate these clamps into position with one hand and they clamp down with a half ton of pressure (about 4 Xs that of a same size c-clamp) with much less effort than a C-clamp. They also come with screw on/off V-block ends for round pipe and tubing. Run about 35.00 each on Amazon and are worth every penny. vertigo
Post #109566
Posted 9/10/2014 3:09:37 PM
Hello Everyone,
So far, I have built my Tumbler without hiring anyone else’s labor(s). That said, I have been tempted to hire others when I have encountered difficulties. The most tempted so far in fabricating the front suspension’s main axles and sheaths. Tempted as I was, I could not bring myself to hire someone else, especially after a machine shop quoted me 1,500.oo each. So, I spent a thousand on a new heavy duty drill press and bits, and in the process saved 2,000.oo more by doing the labor myself. Now, I have a heavy duty drill press so I won't be out any tooling cost when I need a drill press again on my Tumbler build in the future. After all, so far, I have done everything myself. Hiring some else’s labor(s) now just seems like a defeat that I am not willing to accept, at least for now. Maybe in the future after enough frustration, but not now. vertigo
Post #113619
Posted 9/11/2014 10:01:38 PM
Last Login: 8/23/2016 9:26:34 PM
Posts: 15, Visits: 33
Those clamps are awesome I've got four different sizes two of each and your right way better than c-clamps the ones I've got are made by Besse they are a bit speedy but way nice to work with!
Post #114628
Posted 9/12/2014 10:13:57 PM
Hey the bill 69,
Welcome to forum. You sound like you might be a present or future Bat Vehicle builder. vertigo
Post #115640
Posted 9/12/2014 10:21:31 PM
Hello Everyone,
Cut and welded in front of frame firewall and steering braces. vertigo
Post #115641
Posted 9/12/2014 10:25:47 PM
Hello Everyone,
Cut Tumbler arm back suspension shields and firewall. vertigo
Post #115642
Posted 9/12/2014 10:28:04 PM
Hello Everyone,
Welded in Tumbler arm back suspension shields and firewall. vertigo
Post #115643
Posted 9/12/2014 10:31:06 PM
Hello Everyone,
Welded in weapon pod lower shield. vertigo
Post #115644
«««56789»»»
All times are GMT -5:00, Time now is 9:46am
Execution: 0.234. 11 queries. Compression Disabled.
