Vertigo's Tumbler Build
«««2627282930»»»
Posted 4/26/2017 6:35:51 PM
Here is a diagram of the 4-link suspension and truss setup I will be using to set up my GM 14 bolt rear axle.
Post #156684
Posted 4/29/2017 6:49:15 PM
My GM 14 bolt axle weighs 550 pounds. Was looking at my axle and thinking about how I was going to position it for mounting and happen to glance to my Auto-Twirler. So, took one of the end rotation units and I am now using it for axle positioner. Quite effective really, up, down, side to side, and can move forward and backwards.
AUTO TWIRLER-1.jpg (27 views, 320.40 KB)
AUTO TWIRLER-2.jpg (13 views, 285.53 KB)
AUTO TWIRLER-3.jpg (13 views, 304.75 KB)
AUTO TWIRLER-4.jpg (12 views, 305.41 KB)
Post #156712
Posted 4/29/2017 7:05:39 PM
Worked on cutting and fitting structural tubing and other parts to back of Tumbler chassis in preparation of welding and building the 4-link chassis mounts.
chassis mount-1.jpg (27 views, 275.07 KB)
chassis mount-2.jpg (19 views, 350.58 KB)
chassis mount-3.jpg (34 views, 363.00 KB)
Post #156714
Posted 4/30/2017 9:48:39 AM
Wow! I think that last pic is the first I noticed how elaborate your framing is. Beautiful welds too by the way.
Post #156719
Posted 4/30/2017 8:26:35 PM
Thanks for the kind words.
Continued work today on the main axle chassis mounts.
Waiting for my 4-link parts to arrive before I finish cutting and rounding the ends and drilling the holes for the bolts that the hemi joint ends mount on. Once this is achieved welding will be completed and then a 1/4" bottom tension plate will be welded on for additional strength.
chassis mount-4.jpg (27 views, 344.28 KB)
chassis mount-5.jpg (20 views, 379.41 KB)
chassis mount-6.jpg (22 views, 304.14 KB)
chassis mount-7.jpg (25 views, 354.63 KB)
Post #156720
Posted 5/2/2017 6:33:48 PM
That's some heavy duty steel you're using my friend. Your car is going to be a beast!
Seeing that axle coming forward is starting to get pretty exciting!
Post #156734
Posted 5/3/2017 6:47:19 PM
"Wow! I think that last pic is the first I noticed how elaborate your framing is. Beautiful welds too by the way."
Hey sly,
You can go to the early postings on this build to see the frame without any skin.
Post #156738
Posted 5/4/2017 6:28:40 PM
My GM 14 bolt axle drum brakes to disk brakes conversion kit came in today.
Four link-2.jpg (22 views, 381.03 KB)
Post #156746
Posted 5/4/2017 6:40:44 PM
My four link suspension kit with truss for my GM 14 bolt axle came in today.
In the photo image attached to this post the 8 bolts are 5 inches long X 3/4" in diameter.
They make a pretty good scale indicator for anyone wanting to judge the sizes of the
other items in the photo images.
Four link-1.jpg (31 views, 451.78 KB)
Post #156748
Posted 5/5/2017 10:26:17 AM
Really cool. You're starting to move fast now.
Post #156752
«««2627282930»»»
All times are GMT -5:00, Time now is 11:24am
Execution: 0.219. 10 queries. Compression Disabled.
