A VERY slow Batpod build.
«««2930313233»»»
Posted 1/2/2016 5:44:47 AM
Posts: 506, Visits: 8,329
This pushed my CNC to the limit milling to the maximum depth my bit would allow... then the flexible coupler broke so my X axis needed re-aligning... I got it close, but not quite right. Nothing a little filler wont fix.
Post #149236
Posted 1/2/2016 5:51:25 AM
And a video for those who care to look.
Post #149237
Posted 1/2/2016 6:44:00 PM
From the front. The foam wasn't thick enough to make this as wide as I wanted. I'll cast a copy from the back to increase the width and put the two parts together over a steel frame.
Post #149243
Posted 1/16/2016 11:17:30 PM
Canon tip 3D printed.... I like new toys!!
And printing..
Post #149301
Posted 1/17/2016 3:45:06 PM
Another part...
Post #149302
Posted 1/17/2016 6:47:20 PM
Fits.
Post #149303
Posted 1/24/2016 7:44:51 AM
Last Login: 9/24/2018 7:10:03 PM
Posts: 4, Visits: 25
I just wanted to say you do amazing work! Thanks for posting these pics!
Post #149311
Posted 1/24/2016 2:25:42 PM
Thanks.
Post #149312
Posted 2/6/2016 2:36:58 AM
A little more printing done.
Post #149338
Posted 2/23/2016 9:55:31 AM
Posts: 108, Visits: 214
Brad. Looking awesome! I'm finally tinkering with mine again after getting side tracked with a pool remodel this past summer etc. anyway. I found an older post where someone asked about the wheelbase and you said approximately 2310mm hub to hub based on your calculations. Now that yours is built is that a fairly accurate measurement? Thanks in advance!
Post #149366
«««2930313233»»»
All times are GMT -5:00, Time now is 10:33pm
Execution: 0.156. 8 queries. Compression Disabled.
