Posted 4/19/2013 12:34:30 PM |
Last Login: 3/30/2016 11:50:10 PM
Visits: 307
Does any one have the Hoosier part number for the tires. I know the
Tire size is 94/15x15 but not sure of the exact tread pattern
Posted 4/19/2013 10:52:29 PM |
Visits: 8,997
Look through my build log it should be their...
Posted 4/20/2013 12:23:54 PM |
Visits: 307
Posted 7/4/2013 1:57:04 AM |
Last Login: 7/15/2013 1:54:48 AM
Visits: 10
New to the forums, but I contacted Hoosier and this is what they said:
The tire used was a Hoosier 94.0/15.0-15 D20 (part number 31189D20) dirt sprint tire. While this exact tire is no longer offered, it is still available in a slightly different compound. The nearest match to the original tire would be our D12 tire (31189D12).
So that exact tire has been discontinued, but the closest is the part number 31189 with the D12 composite. I hope I helped.
Posted 8/6/2013 8:28:18 PM |
Visits: 8,329
Are both the wheels the same? Podgod wrote " buy the wheels with the center separate (you can weld them in after you get the offset right) because the offset will be different for each rim".
Or is it just a matter of making the design fit the wheels?
Brad.
Posted 8/6/2013 10:14:05 PM |
Visits: 8,329
Or better yet, if someone know the specs of the wheels.. Im chatting to a fellow that sells them and he's asking questions I cant answer.
"Depending on size of the wheel and if u wanted beadlocks or non bead lock and what type wheel centre u need. A 15 dia bye 15 wide wheel with a centre"
Brad.
Posted 8/6/2013 10:15:46 PM |
Visits: 193
Hey spidey! What's the progress on your vehicle?
Posted 8/6/2013 10:18:37 PM |
Visits: 8,329
Sourcing parts at the moment.
Brad.
