Posted 11/4/2012 1:15:37 AM |
Last Login: 1/1/2013 9:04:08 PM
Visits: 119
I'm knew to this and all the info on here is great but what I really could use some blue prints so if someone has some or knows where I could find some it would be great
Posted 12/10/2012 2:54:33 PM |
Visits: 812
There are blueprints all over the internet for the tumbler however almost everyone that I have found has been inaccurate in terms of scale and comparison to the real tumbler. If your going for accuracy be very careful in which blueprints you select as of current I have not found an accurate set of blueprints on the net. With the complexities of the the tumbler your going to need something better then generic blueprints if you plan on building a fairly accurate tumbler if your not to concerned with accuracy then www.the-blueprints.com has the tumbler blueprints but again they are not accurate in terms of comparison with the real tumbler but how accurate you want is for you to decide. The only alternative is to construct the vehicle in a 3d cad program like sketchup where you can dimension the parts for sizes.
