Some Questions of a 66 Batmobile
Some Questions of a 66 Batmobile Expand / Collapse
Posted 9/13/2010 9:38:20 PM
Last Login: 9/21/2010 8:39:51 AM
Posts: 4, Visits: 23
I've loved the 66 Batmobile since I was a kid. I finally have a place to build one, and once the bank account recovered from the garage build and outfitting, I'm thinking of starting my own build of a 66. I have a couple questions about the car in general. Read through a lot of the forum discussion, but saw nothing remotely close to discussion this.
1. Do the rear windshields catch air at highway speeds and cause a lot of buffeting, maybe even enough to rip those rear canopies off?
2. What about handling? Is the 76-79 Lincoln a suitable platform from a handling standpoint? I know the original weighed in at 5500 lbs, but what about the fiberglass kits available today? Obviously, I'd rebuild the suspension with new springs and shocks, but are upgraded and/or performance parts available? If it handles like a pig, that can make things embarassing while driving it, since I'm sure it attracts a lot of attaction, and every yahoo wants to race you.
3. Legality - Are there are problems putting it into car shows? I understand that the nasty lawyers don't want you making any money off their trademarks, so getting paid for public appearances is probably out, huh?
Thanks,
Post #81530
Posted 9/21/2010 8:12:25 AM
Last Login: 2/1/2020 7:34:58 PM
Posts: 38, Visits: 413
To answer some of your questions. I have had my car up to 75mph and the rear canopies hold just fine, and I have customers driving there's with no problems. I matters how you mount them down. some guys use an L-bracket setup. I do not!! I made a channel for the canopies to sit into and use window weld to install them and bolted the center to the arch bar. rock solid!! also make sure when you buy a kit it has 1/4 inch thick canopies that helps too. as far as the Lincoln donor. it's a easier build because everything fits, wheel base, engine height, firewall lines up, wheel track is close etc. they don't handle too bad. you will need to cut the springs a bit. I cut 1 1/2 coils off the front and 1 coil of the rear and it does alright. just be careful under extremely hard acceleration it will wheel hop with the 3 link rear end. and last but not least I showed mine all summer, and had no problems, My car even made the newspapers 4 times. hope this helps
www.batrodz.com
Post #81610
All times are GMT -5:00, Time now is 7:13am
Execution: 0.095. 9 queries. Compression Disabled.
