Posted 6/14/2006 5:37:17 PM |
Okay I just noticed in this screen capture that the left gun appears to be missing the right side plate. Probably because it is legally considered to be the receiver. You can get dummy side plates or semi plates. For me all I needed was dummy guns. Need to remove the rear handle and paint. (same gun different views)
Posted 6/14/2006 6:18:00 PM |
Visits: 421
Sweet Jack! What are the details of yours? Decommissioned or Airsoft or what? They look awesome!
_______________________________________________ When I die, I want to die like my grandfather, who died peacefully in his sleep. Not screaming like all the passengers in his car.
Posted 6/14/2006 6:22:05 PM |
Visits: 421
Here's a nice Hummvee with a demilitarized 50 cal on it: HERE
Posted 6/14/2006 8:22:56 PM |
They are dummy guns, built from original parts but no inners and the barrel is electrical conduit which cut out several pounds. No way it would ever fire, well unless done by propane or SFX. Looks like the sight was also removed from the movie guns. Also, the 1' flange that the gundoor sits on has to be trimed to fit the gun. I have guest over so it will probably be a couple of weeks before I have time to work on installing them. I'll keep you posted. I think Nitro and Kevin also have guns. And then there is the one EP made for the heck of it. I think Nate posted a picture somewhere.
Posted 6/15/2006 10:51:23 AM |
Visits: 421
Are you going to make a belt of ammo coming out the slides like in the screenshot? That would really make people look twice
Posted 6/15/2006 7:55:44 PM |
Yep ammo is a must. I've not been able to find the feeder so I may have to make them or just not have any. I removed the grip and part of the sight. Then painted it cast iron gray and there you have it.
Posted 6/15/2006 8:08:07 PM |
Visits: 4,625
Looks VERY nice Jack.... Thank you for sharing the pics!
Posted 6/15/2006 8:26:00 PM |
You are welcome. I always share.
Posted 6/15/2006 9:42:47 PM |
Posted 6/18/2006 9:44:51 PM |
Visits: 7,280
