Front Turbine Inlet
12345»»»
Front Turbine Inlet Expand / Collapse
Posted 4/16/2006 4:44:15 PM
Ever notice that the bolts that holds the front turbine in place are going different directs? The top ones are going in and the lower ones are going out. Looks like button head allen head bolts and nylon lock nuts.
This info should come in useful for at least one person here. Dave thanks for the pix.
Post #47178
Posted 4/16/2006 5:38:44 PM
Last Login: 3/24/2023 4:37:57 PM
Posts: 2,342, Visits: 8,977
I think the shadow is just hiding it.
Post #47179
Posted 4/16/2006 5:53:39 PM
The shadow is hiding what? If I were you I would stay clear of the Lottery. Yep the top bolts are going in and the lower are going from the inside to the outside. Pictures don't lie...often.
Post #47180
Posted 4/16/2006 8:01:43 PM
I thought you were talking about where the turbine mount pads attach to the fiberglass shell. All three pads attach to the exposed fiberglass shell. I don’t think any would care which way the mount bolt are turned. Nuts should always be on the bottom unless otherwise specified.
Post #47181
Posted 4/16/2006 8:21:25 PM
Lighten up and get Nitro to post that those pix of Mr. Moores Tilting Body.
Post #47182
Posted 4/16/2006 8:37:20 PM
Hey i know why the bolt heads are diffrent because there is a healey coilin those flanges and if you try to tap them out you get a little coil surprise in your hand.
Post #47183
Posted 4/16/2006 9:35:30 PM
That's because it is probably magnesium.
This is why I noticed the bolts.
Post #47184
Posted 4/16/2006 10:00:38 PM
cool
Post #47185
Posted 4/16/2006 10:06:35 PM
Thanks for the can it was perfect.
Post #47186
Posted 4/16/2006 10:09:28 PM
Any time.
Post #47187
12345»»»
All times are GMT -5:00, Time now is 4:02pm
Execution: 0.125. 11 queries. Compression Disabled.
