Posted 12/29/2005 12:37:15 AM |
Visits: 7,280
Posted 12/30/2005 8:01:14 AM |
Someone has a picture of one of Jay's cars that uses a gas shock on a pivoted front track. Maybe he'll share it.
Posted 12/31/2005 12:24:45 AM |
Rusty, here you go. The side rails are actually a little lower in the back. This allows the back of the canopy to rise slightly as it goes forward. Just remember there has to be a pivot point where the rear of the canopy attaches to the linear bearings. Oh they are linear bearings on stainless steel round stock. Kevin has the part numbers. The car had 1/2" stock and bearings; I used 3/4" just so it would completely overdone and add additional weight (or it was because I guessed)....
![Batmobile](http://www.chickslovethecar.com/wm.aspx?ID=8ETEGMVy6jD0rAgxYY0uEFLGu6JjDTuR48LXXzNo%2fOo%3d&DI=MMCfhJ%2bbDyPgg2PPNYRMEsbbpCUINiE%2b)
![Batmobile](http://www.chickslovethecar.com/wm.aspx?ID=8ETEGMVy6jBSR8nVIsy2P1vaS8UvqF%2fkY4aWJCA0aU4%3d&DI=MMCfhJ%2bbDyPgg2PPNYRMEsbbpCUINiE%2b)
The center rail is a whole other beast. Here are the pix that Tim was talking about. It basically another length of round stock and a linear bearing with a pivot point at the front and a gas shock to raise the track at the rear to allow the canopy to go up and then slide forward. I've not worked out how i want to do the center rail yet. I've gotten some good ideas from friends and I know Nitro has a nice set-up.
![Batmobile](http://www.chickslovethecar.com/wm.aspx?ID=8ETEGMVy6jCxQEt7jWXVVvKju49wWF5Quc4y9z1nQZk%3d&DI=MMCfhJ%2bbDyPgg2PPNYRMEsbbpCUINiE%2b)
Now can I drive the General Lee down a closed road where the bridge may be out? I'm sure we can make the jump without any problems.
Posted 12/31/2005 1:16:20 AM |
Hey, I asked him first! (and he never answered, come to think of it... )
I also want to slide across the hood... That's not a problem, is it Rusty?
Posted 12/31/2005 1:26:50 AM |
Visits: 3,239
Those are some nice pics of your setup. The middle track seems really complicated. Why doesn't the whole thing just slide like a van door with a roller in the middle? The roller tracks would just follow the opening and dip right at the back for the seal. Of course, this is my thinking having never actually touched one.
![Smoke](http://www.chickslovethecar.com/board/Skins/CLTC20/Images/EmotIcons/smoke.gif)
Posted 12/31/2005 1:56:19 AM |
That's what I thought too and even came up with some drawings of how it could work. I'm not sure what the best way is...
Posted 12/31/2005 11:45:44 AM |
Visits: 7,280
Posted 12/31/2005 12:25:16 PM |
Since Tim is closer and already has experence driving a Charger I guess he should go first. Also once I jump the dry lake bed i can't promise that it will ever be drivable again......
Posted 12/31/2005 1:23:43 PM |
Visits: 7,280
Posted 1/1/2006 9:47:20 PM |
Visits: 7,280
