Posted 12/23/2005 2:08:45 PM |
Visits: 642
Posted 12/23/2005 8:22:16 PM |
Darren, did you ever print out Tim's PDF of the grills and tape the papers together edge to edge (not trimmed or overlapped, which is what I think you said you did)? What was the overall length from corner to corner like the picture I emailed you?
Tim I'm correct in saying that the PDF had to be printed 100% and then each page taped together edge to edge, correct?
Like it matters but I would still like to know where the size difference is since I took the ouline from the outline on my GA.
Posted 12/23/2005 8:29:00 PM |
Visits: 8,997
I tried it both ways and the curvature was too much of an arch.
Posted 12/23/2005 10:32:42 PM |
Yes Jack, that is correct. It fit nicely on yours, didn't it?
Posted 12/24/2005 5:34:15 AM |
Kevin, print it out, tape it edge to edge, cut it out, put it on your car, take a picture, and post the picture please.
Posted 12/24/2005 11:46:06 AM |
Visits: 2,210
This would be a project right up my alley. would not cost much. someone would have to provide me with a positive of the surrounding area of the vents. If they didn't have vents, were some of the car just sort filled in, if so that would be a problem, or a pain getting it to be functional, and not just cosmetic. Ideally the body should've come out of the mold with a recessed area ready to accept the vents. Then vents that are open, drop into place, and actually serve as a sort of drain.
Posted 12/24/2005 11:54:03 AM |
Last Login: 6/11/2009 2:34:36 PM
Visits: 857
what was the function of the vents on the movie cars?????
Posted 12/24/2005 11:56:45 AM |
Posted 12/24/2005 12:00:51 PM |
Visits: 857
hey is that the cable gey?
Posted 12/24/2005 2:17:22 PM |
Visits: 8,997
Here you go Jack close but not close enough.
