Exhaust Nozzle
1234»»»
Exhaust Nozzle Expand / Collapse
Posted 9/22/2005 6:01:22 PM
Last Login: 3/24/2023 4:37:57 PM
Posts: 2,342, Visits: 8,977
Here is my exhaust and segments; it has an inner liner to keep from having a burn through. I haven’t decided if I want to etch it and paint it with high temp. paint or have it powder coated?
Post #35591
Posted 9/22/2005 6:33:29 PM
Very nice. Did you make it?...
Post #35592
Posted 9/22/2005 6:54:17 PM
Last Login: 4/1/2014 8:49:58 PM
Posts: 320, Visits: 192
That was freaking funny
I was loughing out so loud
Sometimes I wonder what you do all day Tim...
Post #35593
Posted 9/22/2005 7:14:18 PM
Looks great. You should either heat treat it or "blue' it to give it that overheated metal look, like a real turbine.
Post #35594
Posted 9/23/2005 7:44:48 AM
Tim; I tried it your way and I kept on burning up the rear of the car.:laugh
I made templates of all the pieces and had the local sheet metal shop cut all the pieces out galvanized steel for me, a buddy and I put it together, it took both of us five hours to assemble the unit. I used steel rivets on the liner, aluminum ones would come apart with the heat and weight, it weighs a ton.
Post #35595
Posted 9/23/2005 7:59:19 AM
Turned out great. Can't wait to see it finished...
Post #35596
Posted 9/23/2005 8:04:40 AM
Nice job Kevin. Tim yours is nice as well.That other guy in Florida makes a pretty good one also. Kevin would you mind sharing your fuel idea, it sounded great as well as safe.
Post #35597
Posted 9/23/2005 8:22:34 AM
What other guy in Fla. Is there someone I don't know about, or are you janking my jam.
Post #35598
Posted 9/23/2005 8:33:47 AM
I am using a Dragon Exhaust system that uses the spent exhaust gases from your cars engine and ignites them. I will have a small tank of diesel fuel that will be pumped just behind the Dragon Exhaust using spray bars similar to a jet engine. This will atomize the fuel and will be ignited by the primary burner, and Walla a fire ball!!
I got this Idea while I was looking up the tail pipe of my Jet while it was being lit off.:mad
Post #35599
Posted 9/23/2005 8:41:17 AM
Kevin I am sure you know this guy but his name escapes me now.Looks like the guy that used to host C/net. He is the one that has a running car . Only heard download, can't say for sure.
Post #35600
1234»»»
All times are GMT -5:00, Time now is 1:08pm
Execution: 0.141. 8 queries. Compression Disabled.
