Posted 7/17/2005 4:38:12 PM |
Kevin, 2A671B DON'T MAKE ME SEND YOU A CONTRACT!
Posted 7/17/2005 6:12:13 PM |
Ok guys maybe some one has mentioned it or may be they didn't but i was told that the side engine pieces are all turbo parts from the waste gates to the hose clamps,to the flange parts,& inner coolers, the heat sheild .Ok air men what you think? And the little valve with the chain is a hydraulic valve.
Posted 7/17/2005 6:21:52 PM |
I think if that were true you would have set and so would I.
Posted 7/17/2005 6:25:04 PM |
Posted 7/17/2005 6:26:25 PM |
Who ever told you that is on crack.
Posted 7/17/2005 6:46:10 PM |
Airman number 2 what do you think? All others welcome as well.![happy](http://www.chickslovethecar.com/board/Skins/CLTC20/Images/EmotIcons/happy.gif)
Posted 7/17/2005 7:23:28 PM |
Last Login: 5/16/2024 2:01:35 PM
Visits: 8,999
The lines are easily hydraulic or fuel lines, but as far as turbo parts no way. I have worked on numerous general aviation aircraft with turbos with waste gates and they look nothing like that. Most waste gates are very boxy looking. Those parts are from a jet aircraft sub-components, some type of a manifold be it hydraulic, fuel or some type of heat exchanger. Definitely not any type of recip. Engine.
![Burn](http://www.chickslovethecar.com/board/Skins/CLTC20/Images/EmotIcons/burn.gif)
Posted 7/17/2005 7:39:58 PM |
Posted 7/17/2005 7:44:11 PM |
Visits: 4,625
Is that a pic of your helicopter, Jack?
Posted 7/17/2005 7:46:38 PM |
