Posted 6/8/2005 10:33:20 PM |
Visits: 0
Looks like your shop is bigger than mine... :sad
Posted 6/8/2005 10:46:03 PM |
Last Login: 5/10/2004 1:36:17 AM
Visits: 0
3 a month.....Dam now I know I'm in the wrong biz...ha ha
There always seems to be alot of demand for them.........
What's your kit go for Kevin?
Posted 6/9/2005 1:15:14 AM |
Last Login: 5/10/2004 1:36:39 AM
Visits: 0
Dang Kevin you have a nice setup there. Are you the top guy there?
Posted 6/9/2005 1:18:55 AM |
Visits: 0
Jimmy!
What did I tell you about you showing your face here?
Posted 6/9/2005 1:22:12 AM |
Last Login: 5/10/2004 1:36:43 AM
Visits: 0
I thought we liked Jimmy? No?
Posted 6/9/2005 1:35:21 AM |
Visits: 0
Do we?
Tim, what's your opinion on Jimmy?
Posted 6/9/2005 1:54:15 AM |
Visits: 0
I like Jimmy, he speaks his mind but is not an A-hole... Plus we aparently both live in Middle Tennessee.
Posted 6/9/2005 1:55:50 AM |
Visits: 0
Hey Jimmy, want to meet up and see Batman Begins? We can go to Opry Mills and have beers at Jillians first.
Posted 6/9/2005 11:30:37 AM |
Visits: 0
1. 2x4 tube with 3 inch dropped floor all steel.
2. All hinges.
3. Cowl bar.
4. Front lower shock mounts
5. Rear trailing arms.
1. Front wheel wells,cockpit and trunk glassed in.
2. Doors with inner and outer laminated together.
3. Hood with inner and outer laminated together.
4. Trunk with inner and outer laminated together.
5. Dashboard
6. Two fiberglass seat shells
THE BASIC KIT
1. Assembly manual.
2. suppliers list
3. Certificate of Origin ( MSO )
Stage 1 Roller kit consists of:
The basic kit plus
1. Shortened pinto steering rack. 2. HAL coil over shocks.
3. Front and rear sway bars.
4. 84 to 87 corvette front and
rear suspension.(used )
5. Shortened 1/2 shafts for rear.
6. Rear composite spring.
Frame :
Body:
7. All brake hoses.
8. Rotors turned.
9. Rebuilt brake calipers.
10. Rear shocks.
11. All rod ends for trailing arms and sway bars.
12. Gas tank.
Mechanical Components:
90" wheel base $ 6,890.00 96" wheel base $ 7,390.00
90" wheel base $ 10,600.00 96" wheel base $ 11,100.00
I only work there part time, I work full time at the local Police Dept as a CSI, and I do some work out at the Air Port to keep my A&P ticket current.
Posted 6/9/2005 12:56:48 PM |
Visits: 0
I used to work at the A&P too.
