Posted 1/20/2017 12:30:19 AM |
Last Login: 7/6/2017 12:51:16 AM
Visits: 591
FEW MORE PICS
Posted 1/20/2017 12:30:59 AM |
Visits: 591
AND ANOTHER BEFORE THE WEEKEND
Posted 1/23/2017 5:14:39 AM |
Visits: 591
bit more done
Posted 1/23/2017 5:15:14 AM |
Visits: 591
outside
Posted 1/23/2017 1:30:12 PM |
How many pieces did it take to get that curve? Did you cut it before gluing or did you make a rough shape and then sand/plane? I would love to know how you did it.
Also, what is the white filler you are using?
Posted 1/25/2017 6:32:03 AM |
Visits: 591
13 pieces of 12mm plywood cut roughly to shape on a band saw then glued together using normal wood glue (titebond) then roughly shaped using a carving disc in a 4" grinder then final shaping using spoke shave rasps and then finally finishing off with sand/grit paper the filler used is wood filler from a diy company in uk called wickes (it is basically a car body filler but made for wood).
Posted 1/26/2017 12:21:44 AM |
Visits: 591
bit more done
Posted 1/26/2017 12:22:27 AM |
Visits: 591
little more
Posted 1/27/2017 5:23:06 AM |
Visits: 591
little more
Posted 1/27/2017 5:23:59 AM |
Visits: 591
hope everyone is liking
