What rear axle please!
What rear axle please! Expand / Collapse
Posted 12/11/2014 8:37:59 PM
Last Login: 8/11/2015 11:06:28 AM
Posts: 9, Visits: 77
Ok batfans....so now i can weld!,i figured i can do the chassis,get a fairly cheap v8 motor,think iv found a tyre supplier that do similar stuff to swampers,figured out steering using chopped front hubs reversed but im wondering thr best rear axle to use bearing in mind im in the uk,ive heard of dana 30 off a jeep,chevy duelly,any ideas?,plus what about the rear hubs to take the twin wheels,custom made jobies or is anybody using summat already out there??,also cant be street legal due to crappy red tape over here,obviously this would be a massive and long and very hard build but im to determined to forget about it so i need to do this,if we don't believe we will never achieve will we!!,so if you have any info it would be greatly recieved,watching you builders inspires me to try.thanks
Watch for my sign
Post #126097
Posted 12/11/2014 9:26:18 PM
Hey Mattymo36,
Welcome to the forum. Ford 9-inch is stated by many to be in the original Tumbler. Dana 30 way too weak. Dana 60 is stronger than the Ford 9-inch and is the one I am using in my Tumbler. vertigo
Post #126098
Posted 12/11/2014 9:32:28 PM
Hey Mattymo36,
Rear wheels are custom built dually with wheel adapter. No off the shelf available. verttigo
Post #126099
Posted 12/12/2014 12:46:27 AM
Posts: 5,397, Visits: 4,909
Hey Mattymo, Vertigo is right on all accounts. The ford nine inch was trussed up for strength but with a single wheel bearing per side that's a lot of rotating mass to control. The 44 inch TSLs with custom steel rims weigh about 175lbs each. After starting with a Camaro rear end, then I moved onto a custom axle and finally ended up with a chevy eight lug floating axle. Its fricking strong with dual bearings per side. Oh yeah no adapters and steel rims mounted directly to the axle hub.  Hope that helps. BWD
Post #126108
Posted 12/12/2014 6:16:11 AM
Hey guys thanks alot for the bit of knowledge,BWD i do like the sound of the chevy axle with no hub adaptors.also do i realy need to use a v-drive for the motor?,maybe il try get a ball park figure for a axle set up with some hubs......i plan on taking a long long time trying my hardest to build the monster so that will help with the buying bits,oh and my missis has no faith and calls me a dreamer lol,gona do this if it kills me,im lovin all the builds on here and seeing them spurs me on to get crackin
Watch for my sign
Post #127108
Posted 12/12/2014 10:15:35 PM
Hey Mattymo36,
"my missis has no faith and calls me a dreamer"
seeing them spurs me on to get crackin"
You might want to give my postings on do you want to build a Tumbler or other Bat Vehicle
Might give you a few ideas
Post #127110
Posted 12/13/2014 5:42:20 PM
Thanks vertigo...yours and BWD threads were the first i read thoroughly
Watch for my sign
Post #127121
All times are GMT -5:00, Time now is 8:32am
Execution: 0.094. 10 queries. Compression Disabled.
