Maybe cheap light weight wheel bats
Maybe cheap light weight wheel bats Expand / Collapse
Posted 7/7/2007 10:49:03 PM
Full scale Amt model builder
Full scale Amt model builderFull scale Amt model builderFull scale Amt model builderFull scale Amt model builderFull scale Amt model builderFull scale Amt model builderFull scale Amt model builderFull scale Amt model builder
Last Login: Today @ 9:26:45 PM
Posts: 1,079, Visits: 7,365
Guy is on E-bay.
Post #61043
Posted 7/7/2007 11:00:32 PM
Item number: 140136187887. Now that is for a batmobile sign . You can see further down on the listing he makes the bats as well. Not quite the same but if some one was to give him a pattern I bet he could cut them no problem.I think if you were to get a 2x6 and trace a set of wheel bats that would be a great backing and epoxy his chrome /plastic ones to it. The bats would  be light weight ,chrome looking and less dangerous than the heavy aluminum ones.
Post #61044
Posted 7/29/2007 12:46:58 AM
Last Login: 11/25/2008 12:43:34 AM
Posts: 3,148, Visits: 2,407
Hey Nitro I am planning on using those aluminum bat wheels.  I am thinking about drilling into the back and then having it tap in with a fine thread.  On my 89 I am using a floating axle so I will be welding an all-thread nut onto the center of the axle then I am going to use lock-tight to hold it into place.  I will definitely post as we get to that stage but I must say I love these heavy solid aluminum wheels. I am planning on having them polished and sealed.  I was thinking at one time of having them cut out of thick plastic from Tap Plastics.  I was thinking it would be cool to have them light up. BWD
Post #61963
All times are GMT -5:00, Time now is 10:13pm
Execution: 0.109. 11 queries. Compression Disabled.
