T-man's Tumbler go kart
«««2930313233»»»
Posted 8/11/2009 5:12:44 AM
I'm all ready thinking of my next kart ...The C-kart
its going to be 50" x 50" squair from the center point of all the tires( point of contact with the ground) and I'm thinking of placing the motor Behind the rear axle..the box
what do you guys think of that wierd a$$ idea..
Post #76213
Posted 8/11/2009 8:04:11 PM
Alright T-man, put the front tires back on the tumbler! What is a C-kart?
Post #76222
Posted 8/12/2009 2:58:44 AM
ha.. yep those are off the front of the T-kart ..well I have it in mind to initially make 4  primary karts the T, the A, and two C karts. standing for T=Tully, A=Alycia, C=Cristal, and C-Cody..... T-mans T.A.C.C. Karts or maby I should call it the Robin Rod
Got the R&P in today. The rods are not equil length so I'll have to improvise... the length is 38" and I need it to be about 45 1/2 i think, so they'll have to be cut and lengthend. the steering rod come withit ...If this proves to be better then the set-up I have (I think it will ) then theres 4 pages removed from the plans or leave them and let people make there own choice.
I got realy board one day so I built this ...
Its a matter displacement canon that utilizes co-fazed sub-space field harmonics to create a fixed zero point inversion ...well thats what its supposed to be. but all the glue is starting to give way.
Post #76225
Posted 8/12/2009 6:45:58 PM
AAAAA..why does everyone make me look like such a DORK
click here   http://jalopnik.com/5334978/mini+tumbler-built-presumably-for-mini+batman
Post #76237
Posted 8/15/2009 10:23:08 PM
We had the county fair here so we've been busy with the kids but I did find time to do this..
welded and painted the spindles..
then I needed to change the extentions that connects to the spindle and arm rod, well I could find left over steel but not the RH or LH nuts for the ends..so I had to cut and weld...
so once I had that all adjusted right I went for the R&P and cut..
I'll have to wait till monday to go get the steel to extend the R&P.
Post #76288
Posted 8/16/2009 5:40:02 AM
I just put movies on my site..this websit stuff is pritty cool.
Post #76291
Posted 8/23/2009 6:13:37 PM
this is what I have done so far.
I went down and got some DOM tubing 5/8 to be used for the extensions on the R&P, cut them to 6 inches for both sides. Then took off both sides of paneling of the kart and took out the first stuff.
Then connected the ends of the R&P, placed the midle of the R&P, slid the DOM on and centered everything. (if you look close you can see my marks I made with a marker on the extensions of the R&P) then welded.
then started to build the mount for the R&P.
then put it all together....well almost I have to do the steering shaft.
Post #76350
Posted 8/24/2009 1:35:38 PM
Wow, better steering! Hey T-man forgot to ask you, how is the suspension in the front now with the panels on when your driving it?
Post #76358
Posted 8/24/2009 4:27:11 PM
terry, Im sure hopeing the steering works better...The suspention is the same with or without the panels, when I put the stand offs on I made sure that each section of panels were associated with a differant section of the frame .. for example the stand-offs and panel on an arm is one unit so as the arm flexes up and down so does the paneling, the front arm panels are conected to the arm, second / panel 2 is conected to the suspention rap-a-round, and the third is conected to the frame.
Post #76359
Posted 9/10/2009 9:56:24 AM
got the word today that we fly back out to Newark, NJ on the 24th of this month and fly back on the 26th ...
Post #76515
«««2930313233»»»
All times are GMT -5:00, Time now is 11:18pm
