«««7071727374»»»
Posted 4/15/2009 7:53:53 AM
did more on the steering system last night...
Drilling the holes and cutting the rod...let the metal and sparks fly
Post #74528
Posted 4/15/2009 7:57:24 AM
Tacked the brackets....a big oops on that 4th one.
this is a cut rod from the Blaster, it's 3/8ths threaded left and right. this will be the piece that will go from the wheel hub's turning arm to my bracket...ready to be welded.
Post #74529
Posted 4/15/2009 7:58:14 AM
the finished bracket
Post #74530
Posted 4/15/2009 8:01:31 AM
so finally...it turns (although not by much...we'll have to see)
Right Turn
Straight
Left Turn
Post #74531
Posted 4/15/2009 8:07:55 AM
I have to say how dumbfounded I am by how much I just don't know. When I watched T-Mans Tumbler Video he mentioned flipping the wheels for better turning radius. I thought..."BRILLIANT!!"
http://www.youtube.com/watch?v=3DPKf7y1F-Q
Post #74532
Posted 4/15/2009 2:18:09 PM
It  really starts to get exciting when you get the steering hooked up...you'll be so tempted to take it out and test it ... now that is a good thing ...test it out a few times see how it handles test speed and beat on it a little because if anything is to break its better for it to happen BEFOR you put on the panels...
I cant believe that the 6.5hp motor that I'm using on the kart scutes me around so good it has to weigh at least 250 to 300lbs so far.
Post #74533
Posted 4/15/2009 4:19:28 PM
6.5 HP? wow it really was moving you pretty easily. I remember weighing the front half of my build and just that was pushing about 215 lbs. I have the B&S 8HP motor on now, but it's barely welded on. After hearing and seeing what the 6.5 did on yours, i'm going to make SURE that go-kart rear is welded ongood and secure before driving.
Hopefully will be done this weekend with the steering.
I'm enlisting the help of a local guy to bend my round tubing and help with the 4-Link setup. I pick up the axle Next Friday (4/24 hopefully).
Post #74538
Posted 4/15/2009 9:13:45 PM
yep 6.5hp, but remember that I have that jackshaft set-up and that has alot to do with the take-off and torque.
Post #74540
Posted 4/15/2009 10:41:01 PM
it does? how? something to do with the shaft...size?
Post #74543
Posted 4/15/2009 11:18:57 PM
ok guys...
this thing has the exact engine, the axle/transmission, and DUALLY setup i plan to use.
this thing is awesome. now i'm pumped.
http://desert-autosport.ebizautos.com/detail-1999-yamaha-golf_cart-2797935.html
Post #74544
«««7071727374»»»
All times are GMT -5:00, Time now is 12:05am
Execution: 0.406. 10 queries. Compression Disabled.
