T-man's Tumbler go kart
«««678910»»»
Posted 3/1/2009 1:46:55 PM
you may be able to use that slack for your advantage, perhaps push a tensioner next to one of the slacked sides, and if you ever need to remove a chain (for whatever reason) you could simply remove the tensioner, and remove the chain with (probably) never messing with the master link.
Just a suggestion hope it helps
Post #73968
Posted 3/1/2009 9:42:18 PM
Good call, Shag! I was wondering how hard it would be for him to put an adjustable tension device in there... Would be a relatively simple, yet profoundly useful addition!
Post #73979
Posted 3/2/2009 3:39:51 AM
yep I was thinking of that today so I went around on the net and I couldent find anything that would have helped, the tension sprockets that I came across were all to big (2 to 2 1/2" in die. for #41 chain so I just added the 1/8 steel under the jackshaft box and that seems to do the trick.
I also used a piece of angle iron to set and place the brake caliper ...man that was a pain. The white fabric that you see in this picture is called Spectra fabric..its used in alot of stuff from wind sails to bulletproof vests..I use it to cover upthings/parts when I'm welding next to them (its heat tolerance is awesome)
man I am running out of room fast...I even moved a bunch of stuff out of the way..man!
Post #73983
Posted 3/4/2009 2:55:21 AM
Just going around on youtube...WOW talking about scary...I would hate to be chased by this thing.
http://www.youtube.com/watch?v=1uynmApjhWI&feature=related
Post #74007
Posted 3/5/2009 1:09:42 AM
I just got my front hubs in today...
these are the things that I plan on using to connect the rear to the mid frame, there dampeners that (normally )go on a Harley front forks...
if anyone has any better ideas on how I should join these two please post a picture.
Post #74014
Posted 3/5/2009 5:31:36 PM
I think those dampeners are a good way to go, they're nice and simple.
Nice to see you moving right along on your build. So by monday we should be seeing some body panels right?
Post #74034
Posted 3/5/2009 7:59:33 PM
Man I wish, but befor I get into the panels I want to do the steering, pedals, and a few other things. plus the weather has droped about 20 deg. here in the past 3 days. Now if I was doing big stuff I wouldnt have a problem because I would be moving around a lot more but when it comes to doing little stuff where I'm sitting in one spot well thats when I start to get cold.
I was looking at your build last night and you are coming along great also.
has anyone heard from conrad at all??
Post #74035
Posted 3/6/2009 9:22:37 PM
I just got this today, I had ordered for this two weeks ago it works great on 18gage . I'm going to be getting the 20 gage for the kart on mon. or tue., well at least 1 sheet.
I ordered this from Harbor freight...$ 43.00
Post #74050
Posted 3/7/2009 11:50:43 PM
So I went out today and put this spring on the break..
after that I realised that I had a piece of 18 g sheet metal that was sitting behind a bunch of cardboard so I pulled it out and took some measurements and started to cut with my new sheet metal cutter ...what a pain that was...
I placed the sheet on the under side of the kart, marked the bracing, pulled it off, drilled some holes, put it back on , and welded.
and this is what it looks like...fliped over
Post #74057
Posted 3/8/2009 6:51:50 PM
I hit a snag ...I started to to weld the axle brackets on today and the moment I made an arc the welder shut down ...when I pull the triger the relay clicks on and I get power but the thing wont engage the wire ...I checked the fuse and it doesnt look like any of the resisters or diods are burnt..AAAAAAAA HHEELLPP
Post #74061
«««678910»»»
All times are GMT -5:00, Time now is 5:27pm
Execution: 0.219. 10 queries. Compression Disabled.
