Posted 7/13/2005 1:12:24 AM |
Last Login: 12/24/2016 2:32:21 PM
Visits: 17
Ok, so in the movie, the flaps blow off, up come the machine guns and they fire an outline into the door so the batmobile can bust through with no problems. This would indicate the machine guns can move back and forth and up and down...
How did he steer the guns?
Posted 7/13/2005 3:35:52 AM |
Posted 7/13/2005 9:59:45 AM |
Last Login: Yesterday @ 5:59:38 PM
Visits: 8,997
In the real world the guns don't move, they are hard pointed. Anything is possible in the movies.
Posted 7/13/2005 2:49:42 PM |
Last Login: 10/27/2006 4:08:49 PM
Visits: 3
As long as it looks cool!
Posted 7/17/2005 11:01:19 PM |
Last Login: 7/30/2006 10:38:52 PM
Visits: 6
Looks like all you would need is a servo motor to control each gun. Just like motors used to steer remote control cars. If you wanted them to go left/right you just want simple analog servos, if you want left/right by degrees that controller is turned then you want digital servos... or something like that. I worked at Radioshack for 3 years and talked to someone else about this before. Digital steering on remotes is by degree that controller is turned, the more you turn the more it turns. While analog is going to turn 45 degrees left or right no matter how little or how much you turn the controller. If you want to acheive the up/down motion you would have to go with some bidirectional servos like used in large model helicopters I believe. They basically have two servos mounted to one shaft... so that might answer the control issues. Once again I'm not an engineer... just a nerd that worked at Radioshack forever and reads up on anything electronic or science based.
Posted 7/19/2005 2:08:33 AM |
Last Login: 5/27/2009 11:36:04 PM
Visits: 678
OR HIRE A MIDGET AND HAVE HIM SIT ON THE HOOD AND TELL HIM WHAT TO POINT AT
COME TO THE MARKSIDE
Posted 7/19/2005 2:10:26 AM |
Posted 7/19/2005 2:26:18 AM |
Visits: 435
Nananananana Na!!! BATMIDGET!!!
Too funny Mark!
Well it's not like there isn't enough space for them behind the machine guns.
Wanted:
Twin Midgets to ride on the hood of long, black, limo-like vehicle. Must be willing to work evenings and weekends. Must have NRA membership, black wetsuits and firm grip. Firearms experience and 20/20 vision a plus. Send resume and photo to Wayne Enterprises C/O Mark Towle.
"Where does he get those wonderful toys?" He MAKES them you idiot! www.tunergirlz.com www.codeoneauto.com
Posted 7/21/2005 2:03:19 PM |
Check it out.
Center flap(?) opens up
Posted 7/21/2005 2:17:54 PM |
Which ones? point....
Another great picture. Did you get me PM or email?
