«««8788899091»»»
Posted 5/5/2023 7:52:37 AM
Posts: 210, Visits: 2,297
Nice one Sly. Glad to see some progress...
Have you tried folding the matt yet for those sharp angles?
Post #170829
Posted 5/6/2023 4:52:17 PM
Not yet. I've been inundated with other commitments lately. But just finished the last one today so should have a clear path to work on it next week........ if the weather holds out.
Post #170830
Posted 5/8/2023 3:25:56 PM
Working on the Driver's Side Front Side Box and I need some advice. Because the space is too narrow to get into the mold to lay the fiberglass, I mixed up a gallon of resin and filled it with fiberglass fibers then poured the mixture into the mold. It has worked OK but I'm concerned with the strength over time. This section is connected to the rest of the part, as I lay five layers of fiberglass over it when making the rest of the part. But it is connected, not encased, if you understand my meaning.
So, do you think this is fine? Or do I need to lay an extra layer of fiberglass outside the part when it comes out of the mold?
Also, I screwed up a bit on this box. In my haste to get to work on it, I forgot to cover the "lines" with a layer of fiberglass grains like I di on the other boxes. So, I couldn't get the fiberglass mat to mold to the lines without bubbling. Yes, I'm an idiot! But I'm not going to do the whole thing over again, I'm going to try and fix it with body filler when it comes out of the mold.
Post #170831
Posted 5/9/2023 10:38:42 PM
slysnake (5/6/2023)
We all are. Never ending drama and fire to put out. But good to know you have everything in control.
Post #170832
Posted 5/11/2023 6:10:06 PM
Separated the part from the mold today.
Overall, it came out OK. The lines were a bit wide but not really as bad as I thought they might be. I think they can be fixed in the body work phase.
I couldn't resist putting it all together to see what it kind of looked like. The main body is at THEMAN's shop, but I still have the molds. So, I bolted it together and put it on top of the side boxes for fun.
These side boxes represent the distance from the floor of the car. The windscreen is pretty narrow on top. But I checked with codes in my state and it is acceptable.
Post #170836
Posted 5/12/2023 7:10:03 AM
Last Login: 4/7/2024 8:21:03 AM
Posts: 44, Visits: 442
Outstanding sir thank you for sharing your progress
Post #170837
Posted 5/12/2023 7:00:07 PM
Thanks brother
Post #170838
Posted 5/14/2023 9:21:25 PM
Very wicked and inspiring. Impressive workmanship and momentum. vertigo
Post #170839
Posted 5/15/2023 10:12:54 AM
Thanks Vert. I'm still looking into what we talked about.
Post #170840
Posted 5/18/2023 5:52:33 AM
Last Login: 10/18/2023 12:03:11 PM
Posts: 94, Visits: 5,982
That looks super cool. Seeing the molds bolted up that way really paints a crazy amazing looking picture.
David
Post #170844
«««8788899091»»»
All times are GMT -5:00, Time now is 10:47pm
Execution: 0.125. 10 queries. Compression Disabled.
