A VERY slow Batpod build.
«««4344454647
A VERY slow Batpod build. Expand / Collapse
Posted 10/25/2020 1:51:29 AM
A few more little bits to fabricate.. then onto V2!!
Post #168870
Posted 10/25/2020 3:57:13 PM
Wow! That looks awesome!
Post #168874
Posted 10/25/2020 7:08:59 PM
Now that is one wicked machine. vertigo
Post #168878
Posted 10/25/2020 7:10:42 PM
hey spidey,
What kind of 3D printer do you use and recommend? vertigo
Post #168879
Posted 10/25/2020 8:32:33 PM
A very modified and upgraded CR10 3d printer. 40x40x40 build volume.
Post #168880
Posted 10/26/2020 10:44:42 AM
Last Login: 7/15/2021 8:35:20 AM
Posts: 63, Visits: 271
Any notable physical changes to V2 that you have planned?
-Waz
Post #168881
Posted 10/27/2020 12:24:27 AM
V2 will have 2 sets of tires / wheels. Hoosiers and Vee Rubber Monster so I can swap over depending on what Im doing with it. I've ordered / received the same motor but spending a little more on batteries. Current battery pack can safely pull 60amps. Next pack will allow 300amps for acceleration (30sec) and 150amps (continuous) . V2 will behave like a Batpod should. Few other little things, but nothing of consequence.
Arm Guards... V2
Post #168882
Posted 10/29/2020 8:51:48 AM
Posts: 1,214, Visits: 3,970
I'm thinking I'm going to have to tackle one of these builds next
First I need to finish off my single seater project!
Post #168885
Posted 12/3/2020 6:00:35 PM
hey spidey,
What type and brand of filament do you use in your 3D printing projects? vertigo
Post #168979
Posted 11/15/2021 4:17:33 PM
Placed a copy of this post here for anyone planning to and/or building an electric bat vehicle.
Ford invents cable that can charge electric cars in about 5 minutes
Gary Gastelu
https://www.msn.com/en-us/autos/news/ford-invents-cable-that-can-charge-electric-cars-in-about-5-minutes/ar-AAQIXx0?ocid=msedgdhp&pc=U531
Ford wants to hot-wire your car.
"The automaker and Purdue University are co-developing a charging cable for use with high-power charging stations that could recharge an electric vehicle's battery in the same time it takes to fill a gas tank, which typically takes about five minutes
The cable features a unique liquid cooling system that can phase the liquid into vapor, which improves its ability to dissipate heat.
"Today, chargers are limited in how quickly they can charge an EV’s battery due to the danger of overheating. Charging faster requires more current to travel through the charging cable," Michael Degner, senior technical leader, Ford Research and Advanced Engineering, said.
"The higher the current, the greater the amount of heat that has to be removed to keep the cable operational."
The most powerful stations currently in use can charge an electric car to 80% in 20 to 40 minutes and new cable designs will be required to increase the speed as battery and charging network technology improves.
A timeline for the rollout of the new cable has not been announced, but a patent application has been filed to protect the intellectual property."
Post #169938
«««4344454647
All times are GMT -5:00, Time now is 5:49am
Execution: 0.156. 10 queries. Compression Disabled.
