BATMAN v SUPERMAN Dawn of Justice BATMOBILE
«««6364656667»»»
BATMAN v SUPERMAN Dawn of Justice BATMOBILE Expand / Collapse
Posted 4/18/2020 12:24:51 PM
Ever think of building your own? I could hook you up with some good stuff. Just let me know.
Post #168454
Posted 4/18/2020 2:11:02 PM
Already have a 4' x 4' CNC torchmate plasma table.
All I have to do to convert it into a router table is substitute a Z axis with router mount for the arc height control unit.
Post #168456
Posted 4/18/2020 8:46:14 PM
A few photo-images of my CNC TORCHMATE table.
Already have a 4' x 4' CNC TORCHMATE plasma table.
TORCHMATE 6.png (6 views, 914.47 KB)
TORCHMATE 3.png (5 views, 943.42 KB)
TORCHMATE 1.png (4 views, 881.82 KB)
TORCHMATE 2.png (3 views, 1.03 MB)
TORCHMATE 8.png (3 views, 940.83 KB)
Post #168457
Posted 4/20/2020 6:10:48 PM
Yes, I remember that from your past posts.
Post #168462
Posted 10/23/2020 12:29:18 PM
SSC Tuatara Set Top Speed Record On Regular Michelin Tires
That's Right. Regular Michelin Tires. 335 Miles Per Hour
UTQG: 180AAA, SPEED RATING: Y, CLASS: XL, An excellent tire for racing enthusiasts, the Michelin Pilot Sport Cup 2 provides your sports car or exotic vehicle with superb dry grip and keen handling. This summer tire delivers competition performance using a bi-compound technology, one that features an endurance racing compound in the outer tread and a rigid elastomer in the inner tread. The tire can withstand extensive laps, as its built with Michelins Track Longevity Technology that combines a special variable contact patch and reinforced shoulder construction. Thanks to this increased durability, the Michelin Pilot Sports Cup 2 UHP tire can help your sports car achieve optimal track results.
These tires range in prices from 300-770.oo.
pilot tire-1.jpg (4 views, 15.90 KB)
Post #168864
Posted 10/24/2020 8:27:03 PM
Placed a copy of this post here for anyone planning to and or building a Bat Vehicle.
This is the best introductory book I have read on 3D printers.
CNC-Designing 3D Printers - Genuine or cheap parts.
by Neil Rosenburg
"Why are genuine products/parts more expensive? It is often the case that only the originating inventor/maker truly understands the design intent of fine details. It is equally true that these fine details are frequently the "magic" that makes it work right. The extra care plus the cost of development, testing, refinement are built into the true cost of the product.
WHY COPY CATS ARE RISKY
A copy cat producer's primary motivation is to make something as cheaply as possible.
Their engineers may not fully understand why certain features, dimensions, materials, and etc. were designed as they were in the genuine article. They also may not be skilled enough to accurately reverse engineer the target product. It may even be that their own vendors cut corner for the very same reasons."
The more complex and tolerance dependent the part/assembly is, the more likely you are likely to get burned with a copy cat or cheap similar part/assembly. Usually, materials, dimensions, alignments, function, integration, all suffer.
Post #168869
Posted 10/25/2020 7:05:30 PM
Given that I am planning to use 3D printing to make some of the parts for my Tumbler and Justice League Bat Vehicles I am researching 3D technology and printers.
QIDI TECH Large Size Intelligent Industrial Grade 3D Printer New Model:X-max,5 Inch Touchscreen,WiFi Function,High Precision Printing with ABS,PLA,TPU,Flexible Filament,300x250x300mm
Visit the R QIDI TECHNOLOGY Store
Price: $1,199.00 & FREE Shipping. Details
The X-Max with pioneered creation of two different ways for placing the filament. Ventilative printing or enclosed constant temperature printing for you to choose when printing the different types of filament.
5-inch full color touchscreen with intuitive icons makes for easy operation
Build size: 300mm x 250mm x 300mm / 11.8" x 9.8" x 11.8"
Full metal support more stable than plastic support;Aviation aluminum, CNC machining aluminum alloy
QIDI TECH Professional Amazon after-service team,if you have any problem about our 3d printer,we will reply to you within 24 hours.Free one-year warranty.
Specifications for this item
Brand Name R QIDI TECHNOLOGY
Item Weight 61.7 pounds
Material Acrylic
Model Number QDMAX201905
Number of Items 1
Part Number QDMAX201905
Specification Met
UNSPSC Code 40000000
3D Printed Lamborgini.jpg (7 views, 384.83 KB)
3D Printed Lamborgini-2.jpg (7 views, 69.62 KB)
3D Printed Lamborgini-3.jpg (7 views, 79.26 KB)
Post #168877
Posted 10/29/2020 5:14:59 PM
Just watched Jay Leno's Garage on demand
Season 2 Episode 2
6-23-2016
about a quarter of the show was about the DOJ Batmobile
other footage was of the 89 and 66 along with a guest appearance by Adam West.
Post #168886
Posted 10/30/2020 6:03:18 AM
Any revelations? I'll have to check it out
Post #168887
Posted 10/31/2020 7:06:58 PM
What would Alfred say?What would Alfred say?What would Alfred say?What would Alfred say?What would Alfred say?What would Alfred say?What would Alfred say?What would Alfred say?
Posts: 195, Visits: 745
X-MAX is what I have - just AWESOME!!!
I will comment that the only thing that I might have a complaint on is the build plate leveling thumbscrew locking wingnuts. When you level the build plate, you make finite vertical adjustments using a thumbscrew. In theory, once adjusted to the correct height, you "lock" the thumbscrew position with the wing nut. The issue is - that when you tighten the "locking" wing nut, it moves the leveling bolt ever so slightly due to the clearances in the major/minor thread diameters/pitches in the thumbscrew, which effectively changes the vertical position of your build plate. ARG!
But none to worry - If you do happen to go out and buy a X-MAX (and I highly recommend it!), I have modeled some PETG thumbscrews that have a plain old M4-.70 nylon lock nut inserted to act as the locking device, so the build plate leveling is now a true set-n-forget op...
Post #168892
«««6364656667»»»
All times are GMT -5:00, Time now is 10:55pm
Execution: 0.156. 11 queries. Compression Disabled.
