Posted 7/7/2020 7:43:28 PM |
Visits: 1,037
1st pic is the sway bar 2nd pic is what we’ve been calling the lower pitman arm the box thing it a linear motion ball bearing block
Posted 7/8/2020 7:27:22 AM |
Last Login: 6/12/2021 8:10:15 AM
Visits: 172
Posted 9/14/2020 4:20:10 AM |
Visits: 172
@towman....bro,what is this part..its not pit arm....thnx
Posted 10/15/2020 6:34:45 PM |
I have current plans to make several major and a number of minor parts for both my Tumbler and Justice League Bat Vehicles.
Given their significant involvement with several current Bat Vehicle builds it very likely that 3D printers will continue to be even more involved in future Bat Vehicle builds.
Here is an outstanding book written in plain English without all the techno jargon that covers the principles and construction techniques of building 3D printers.
Designing 3D Printers: Essential Knowledge Paperback – July 28, 2019
Paperback
$27.21
Product details
Paperback : 197 pages
Item Weight : 1.29 pounds
ISBN-13 : 978-1082381867
Product Dimensions : 8.5 x 0.47 x 11 inches
ISBN-10 : 1082381861
Publisher : Independently published (July 28, 2019)
Language: : English
Posted 10/16/2020 11:36:26 AM |
I think a 3d printer is in my future so this resource will come in quite handy. Thanks Vert.
Posted 10/24/2020 8:25:45 PM |
Placed a copy of this post here for anyone planning to and or building a Bat Vehicle.
This is the best introductory book I have read on 3D printers.
CNC-Designing 3D Printers - Genuine or cheap parts.
by Neil Rosenburg
"Why are genuine products/parts more expensive? It is often the case that only the originating inventor/maker truly understands the design intent of fine details. It is equally true that these fine details are frequently the "magic" that makes it work right. The extra care plus the cost of development, testing, refinement are built into the true cost of the product.
WHY COPY CATS ARE RISKY
A copy cat producer's primary motivation is to make something as cheaply as possible.
Their engineers may not fully understand why certain features, dimensions, materials, and etc. were designed as they were in the genuine article. They also may not be skilled enough to accurately reverse engineer the target product. It may even be that their own vendors cut corner for the very same reasons."
The more complex and tolerance dependent the part/assembly is, the more likely you are likely to get burned with a copy cat or cheap similar part/assembly. Usually, materials, dimensions, alignments, function, integration, all suffer.
Posted 10/25/2020 7:02:43 PM |
Given that I am planning to use 3D printing to make some of the parts for my Tumbler and Justice League Bat Vehicles I am researching 3D technology and printers.
QIDI TECH Large Size Intelligent Industrial Grade 3D Printer New Model:X-max,5 Inch Touchscreen,WiFi Function,High Precision Printing with ABS,PLA,TPU,Flexible Filament,300x250x300mm
Visit the R QIDI TECHNOLOGY Store
Price: $1,199.00 & FREE Shipping. Details
The X-Max with pioneered creation of two different ways for placing the filament. Ventilative printing or enclosed constant temperature printing for you to choose when printing the different types of filament.
5-inch full color touchscreen with intuitive icons makes for easy operation
Build size: 300mm x 250mm x 300mm / 11.8" x 9.8" x 11.8"
Full metal support more stable than plastic support;Aviation aluminum, CNC machining aluminum alloy
QIDI TECH Professional Amazon after-service team,if you have any problem about our 3d printer,we will reply to you within 24 hours.Free one-year warranty.
Specifications for this item
Brand Name R QIDI TECHNOLOGY
Item Weight 61.7 pounds
Material Acrylic
Model Number QDMAX201905
Number of Items 1
Part Number QDMAX201905
Specification Met
UNSPSC Code 40000000
Posted 11/17/2020 5:59:25 PM |
Here is a photo-image of a Batman Tumbler themed bed and room.
Posted 11/17/2020 6:29:35 PM |
Posted 11/23/2020 8:04:46 PM |
Received an email asking, What 3D printer for around 1,000.oo has the best quality with the largest printing area and volume?
After searching for and studying 3D printers with these parameters I came to the conclusion that the CREALITY CR-10 MAX 3D printer that sells for 999.99 fit these parameters the best.
https://creality3d.shop/collections/3d-printer
Anyone out there have a different 3D printer recommendation for the stated set of parameters?
