Posted 7/28/2020 9:19:51 PM |
Lights functional.
Posted 7/29/2020 12:00:16 AM |
Amazing.
How do you turn? Is it like the actual movie prop where the rider leans left and right to make the turn?
Posted 7/29/2020 3:48:57 AM |
You lean the bike to turn. The flat tyre surface is a problem so the higher the air preassure the more ballon the tyres get. I thought about shaving the edges of the tyres like they did on the movie bikes, but never got around to it.
Posted 8/12/2020 5:48:41 PM |
Wired up light switch.
Posted 8/13/2020 1:51:42 PM |
Very nice. What's the approximate run time for the battery. How many kilometers on a charge?
Posted 8/13/2020 5:09:06 PM |
It's like any vehicle. Depends how hard you push it. I've a 20amp hour battery and just riding around it pulls between 30 - 60 amps depending on the slope of the surface. Upgrade the battery and you'll get more out of it.
Posted 10/7/2020 5:14:12 AM |
Posted 10/7/2020 4:44:51 PM |
Looks great. What putty are you using?
Posted 10/7/2020 7:02:05 PM |
It's a two part mix called builders bog. Also using a filler spray to help with the fine sanding lines.
Posted 10/8/2020 7:53:45 AM |
builders bog. That's new to me. I wonder if it's available in the US
