Posted 5/16/2017 8:13:15 PM |
“Man, that looks sweet! It would be cool if you did a video on the
weld. Is that too much to ask?”
Not really set up to do video but I plan to show in great detail how I
welded and tested by destruction my hemi-joint threaded tubing inserts
(bungs). This will be reflective of my unique and particular
hemi-joint threaded tubing insert (bung) welding experience and only
relevant to the variables related to my particular set of materials,
welding, and weld testing. If the welding of my hemi-joint threaded
tubing inserts is successful, it is in no way a guarantee, that
someone else with a different set of materials, machines, welding
abilities, methods, and technique variables would achieve the same
results.
I currently have four extra hemi-joint threaded tubing inserts on
order to be used for welding and weld testing by destruction. I have
added this from the Miller Welding forum
MILLER WELDING FORUM: Hemi-joint threaded insert welding.
Note: Suspension and steering related hemi-joints are considered to be
critical welded parts in that weld/part failures could result in
severe injury and death. If you don’t have absolute confidence in your
parts/materials, welding, and weld testing, knowledge and abilities,
take them to a professional welder.
Here is the related posting.
“Now some will say they got nice hot welds on the bungs they did with
MIG. I do not know what their experience is but having a MIG weld go
in "nice and hot" is certainly no guarantee if it is sound or not.
Only practicing and destruction testing on your welds will show if
welding and parameters were correct. So, I buy some extra bungs and
weld them as practice. Once welded, I cut long and sideways through
the center and examine for fusion. This is the only way I can know for
certain. Anytime I change any variable such as tubing material, even
the thickness, hemi-joint threaded insert material/dimensions, welding
wire/rod, welder settings, etc. I destruction test the new welded
combination. It is the only way I can be certain that my welding and
parameters were correct.”
Posted 5/17/2017 7:17:14 PM |
I posted a copy of this post here because it might be of some benefit
to anyone planning, starting, or currently building a Batman Tumbler.
Here from weldguru.com is the best and most comprehensive article I
have ever seen on the web for assessing and testing the quality of
welds. I put the table of contents below. Go to weldguru.com to read
the whole 2593 words on the subject. It is very informative and worth
reading for anyone interested in, and/or worried about the quality of
their welds. vertigo
Guide to Weld Quality Testing
“To ensure the satisfactory performance of a welded structure, the
quality of the welds must be determined by adequate testing procedures.
Therefore, they are proof tested under conditions that are the same or
more severe than those encountered by the welded structures in the
field.”
This page contains visual inspection tips. The following pages contain
inspection methods for GMAW and physical weld testing.
Table of Contents
Visual Inspection Methods
Lack of Fusion
Undercutting
Incomplete Penetration
Slag Inclusions
Porosity
Gas Weld Testing
Physical Weld Tests
Acid Etch Test
Guided Bend Test
Free Bend Test
Back Bend Test
Nick Break Test
Tensile Strength Test
Hydrostatic Test
Magnetic Particle Test
X-Ray Testing
Gamma Ray Testing
Flourescent Penetrant Test
Hardness Tests
Magnaflux Tests
Electromagnetic Tests
Acoustic Emission Testing
Ferrite Testing
Posted 5/18/2017 7:54:48 PM |
to anyone planning, starting, or currently building a Bat Vehicle.
Here is one the most comprehensive websites I have found for MIG welding.
Weldguru.com
“Hi, my name is Garrett… (owner of weldguru.com)
For the past 5 years I’ve helped well over 10,000 beginners and
hobbyists get started learning to mig weld through my free training.
If you’d like to get started, Download my FREE beginner’s guide to MIG
welding.”
Posted 5/19/2017 11:53:06 AM |
Posted 5/19/2017 8:12:35 PM |
With the recent postings focus on welding I have decide to post on a
question frequently asked of me by those interested in or new to
welding.
“What is the best start out welding book for someone wanting to learn
about or improve on their minimal welding abilities?”
The best current book that meets the needs of those wanting to learn
about or improve their minimal welding abilities is: The Art of
Welding
It really has no current competition in succinct to the point
descriptive text or quality of photo images and illustrations.
Many Junior High schools, High schools, colleges, and welding schools
now use this as their 101 welding introduction text.
The Art of Welding
by William Galvery
former Professor of Welding Technology
Orange Coast College of California
With input from Ryan Friedlinghaus
Founder and CEO of West Coast Customs
Copyright 2014
Industrial Press
32 Haviland Street
South Norwalk, Connecticut 06854
Toll free: 1-888-528-7852
www.industrialpress.com
Standard Edition: ISBN 978-0-8311-3475-4
Praxair Edition: ISBN 978-0-8311-3488-4 (this is the edition I have)
Cost approximately: 20.oo
Posted 5/23/2017 6:29:23 PM |
Well, finally got all four of my SAM-43 Super Swamper rear tires for my Tumbler.
Quite impressive close up.
Posted 5/23/2017 8:39:36 PM |
Nice! What's the height of those tires?
Posted 5/23/2017 11:34:02 PM |
So cool...
Posted 5/24/2017 4:38:43 AM |
Last Login: 3/31/2020 4:09:05 AM
Visits: 995
Posted 5/24/2017 7:45:06 PM |
How tall are these tires?
Interco list them as 44 x 18.5-16.50
One spec sheet refers to a Tire Diameter Range:
44.0-44.99 inches
At 70 degrees cold the tire is 44.0 inches tall
Once the tire starts rolling, and/or the temperature increases, the
tire will expand.
Throughout the operational range the tire is not supposed to expand
more than an inch in diameter.
There is no information on the range of width expansion throughout the
operational range.
I guess they don’t consider the width expansion variation as important
since the tires were not envisioned to be used in a dually
configuration. Probably the same reason there are no 16.5” dually
steel wheels for these tires
