89 build - what radiator did you use? (95 caprice / LT1)
89 build - what radiator did you use? (95... Expand / Collapse
Posted 11/17/2016 7:45:23 PM
Last Login: 9/27/2021 4:59:23 PM
Posts: 62, Visits: 344
Wondering if anyone can assist here...the factory radiator will not fit....hoping somebody can share some info to help me find the right radiator that will go with my engine as well....let me know, thanks!
Post #150670
Posted 11/18/2016 4:40:28 AM
Last Login: 6/14/2021 4:42:58 AM
Posts: 258, Visits: 1,372
You need to get a custom one made and make sure you get one with the shroud. Is the point of the build where you realize that everything needs to be custom made to fit
my greatest gift is my kids thanks to them i get to play with toys
Post #150671
Posted 11/18/2016 7:22:35 AM
Last Login: 3/25/2024 6:05:45 AM
Posts: 267, Visits: 2,294
Speedway Motors has quite a few configurations of radiators available. take your measurements, and likely they will have one that suits your needs.
To build the impossible dream . . .
Post #150672
Posted 11/18/2016 7:55:46 AM
Make sure the configuration you get allows you to put a cooling fan on it also look to see where your top and bottom radiator hose goes to your engine because some of you universal hoses are either so stiff they will not work well in tight configurations or the hose lacks the support to stay open and allow them to literally suck shut causing your car to overheat also depending on your engine, car engines from the early 80"s and before need 160 thermostat s. they will run hot with what most parts places recommend.I run aluminum 4 core with water pump fan and cooling fan blowing towards engine.
Post #150673
All times are GMT -5:00, Time now is 3:14pm
Execution: 0.156. 10 queries. Compression Disabled.
