Posted 1/29/2015 3:16:53 PM |
Visits: 5,479
Now you say it, it all makes sense. Good luck on your build and I look forward to following your progress.
Posted 2/9/2015 9:48:35 PM |
Last Login: 11/17/2023 11:50:54 PM
Visits: 1,326
Rear of the chassis before surgery
IRS with the mounting bracket I am making up
Getting the gantry crane setup to lift the chassis up
Some pics of the IRS brackets being attached
Also bought a donor car. Its a 2000 Holden Commodore. Has a 5.7 litre V8 which should go nice
Posted 3/4/2015 6:13:20 PM |
Visits: 1,326
So it would appear I have gone for the Flintstone look here with the wooden wheels!
I don't have the rims and tyres yet, so I figured I had better mock up something of the same size so I could check the ride height front and rear, before I went and commited to welding the rear axle on fully.
Just as well as I did, as it turns out the IRS doesn't have enough upward travel in it's a-arms to get it to sit right.
The only way to fix this would have been to pull the whole IRS setup further back on the chassis, which means it will sit higher as the chassis rails are going up at an angle. This in turn means the seats would need to go further back, but the problem here is that the chassis starts to narrow. So the seats would be very close together with no room for the driveshaft tunnel.
So basically I am tossing the IRS, and going to a solid diff with a 4-link.
This comes a week after I sold the solid diff off the chassis I was using ! No loss, as it was drum brakes on the rear. I will be sourcing a modern diff with disc brakes off a Ford Falcon to use with the 4-link.
In other news Doug has nearly finished my shell. So it will be starting its long journey to me soon.
Oh and I've sold this house and moved into a rental with a tiny shed. So that will be a pain to be making stuff!
Posted 3/4/2015 6:53:19 PM |
Last Login: 7/3/2023 1:44:12 PM
Visits: 6,742
Looking great, good luck on your build!
Like the donor car!
Posted 3/4/2015 9:31:08 PM |
Last Login: 10/1/2023 8:00:41 PM
Visits: 1,388
Nice to see someone using a IRS and I'm enjoying your build
I have a 96 Thunderbird with IRS that I was going to use if I used Crown Vic chassis. The problem I has with 90 Ford Supercoupe was major wheel hop leaving the line. I do know that people use the same rear-end in Cobra kits and stuff w/o and problem.
Posted 3/30/2015 12:55:10 AM |
Visits: 1,326
So i found myself a solid axle from what is called a Falcon here. XR8 to be specific.
it came with a 4-link on it, but it turns out all the brackets were in the wrong spot in relation to my chassis. Lucky cause I had just ordered a triangular 4-link the day before. Phew
So I cut all the brackets and crap off the diff to get ready to fix the new 4-link on
Posted 3/30/2015 1:02:04 AM |
Visits: 1,326
Here is my pretty triangular 4-link still in the box
Getting it all setup
Picked up this baby to help make short work of cutting crap out and also making new parts. My nice new plasma cutter
Posted 3/30/2015 1:05:29 AM |
Visits: 1,326
Great news my shell has left Ohio. Got to LA pretty quick! Only cost me 1 leg so that's ok can still use the other one to walk on
And here it is sitting at the freight company near Long Beach CA
Should be to me in Australia by the end of April!
Posted 3/30/2015 5:58:40 AM |
Looks Great I am very happy for you.
Posted 3/30/2015 9:44:37 PM |
THATS AWESOME NEWS!! Here's sending good vibes that it arrives soon (and safe)!
