Vertigo's Tumbler Build
«««7475767778»»»
Posted 11/17/2021 6:21:13 PM
Last Login: Today @ 1:03:33 AM
Posts: 3,137, Visits: 4,843
Currently, I am working around an hour a day on my Tumbler and Justice League bat vehicle builds.
Following a part/module/assembly building pathway that progresses through models/planning/paper, then to wood/cardboard proxy building, and finally to proxy translation into finished steel/fiberglass.
No camera ready progress at this time. vertigo
Post #169955
Posted 11/22/2021 8:55:17 PM
For anyone planning to and/or building a batman tumbler: 3rd edition black 1/6th Batman Tumblers for 630.oo
For the past three years Hot Toys 2nd edition 1/6th Batman Tumbler models in black have been selling on eBay for a low of 2,000 to a high of 3600.oo.
Sideshow / Hot Toys is now taking orders for 3rd edition run of 500 Hot Toys 1/6th Batman Tumbler for 630.oo
Sixth Scale Batman Tumbler by Hot Toys
Movie Masterpiece Series - Batman Begins
HOT TOYS
$630
ABOUT THIS SIXTH SCALE FIGURE ACCESSORY
The Batmobile is on its way to fight crime in Gotham City! As one of the iconic bat gadgets, the technologically advanced Batmobile is a heavily armored tactical assault vehicle in Batman’s arsenal.
Based on Christopher Nolan’s The Dark Knight trilogy, Sideshow and Hot Toys present the super-vehicle Batmobile as a stunning sixth scale collectible vehicle that can be paired with Batman figure to recreate more breathtaking scenes!
The highly-detailed collectible has captured Batmobile’s appearance in the movie with extreme precision and outstanding painting applications, complemented with perfectly scaled design and mechanical details throughout its interior and body. Measuring at approximately 73cm in length, it features LED light-up functions throughout the vehicle body; rotatable rubber tires; also more exquisite mechanical features such as slide-open roof panel, and articulated breaking flaps.
Pick up the Batmobile Collectible Vehicle now for your Bat collections now.
The Batmobile Sixth Scale Collectible Vehicle features:
Authentically and detailed Batmobile in Batman Begins
Highly-accurate paint application on the interior and mechanical design
Approximately 73cm L x 46cm W x 27cm H
10 LED light-up points throughout body of the vehicle (white light, battery operated)
Detailed cockpit/ roof opening panel structure
Articulated breaking flaps
Rotatable rubber tires
Sized to fit with 1/6th scale Batman Collectible Figure
ADDITIONAL DETAILS & DIMENSIONS
Materials
Product Size
Height: 10.62" (27 cm)
Width: 28.74" (73 cm)
Depth: 18.11" (46 cm) *
Post #169972
Posted 11/22/2021 10:45:06 PM
Last Login: 3/23/2022 2:36:23 AM
Posts: 141, Visits: 999
WOW thats good to know.
Is it on their site or where did you see it?
Post #169973
Posted 11/23/2021 7:46:20 AM
hey WARMachine,
https://www.sideshow.com/hot-toys/dc-comics#/filter:character:Batmobile
Post #169975
Posted 12/8/2021 6:59:11 PM
Placed a copy of this posting here for anyone who might be planning to, and/or actually building a bat vehicle.
Received an email today stating,
"I am designing a stretched and modified frame for a bat mobile. What is easiest way to make the frame more ridged and less effected by torque and bending?
The "easiest way to make the frame more ridged and less effected by torque and bending", also known as, twisting loads and vertical/horizontal bending, is to add X s and angles.
A photo-image is worth a thousand words as the one I have attached demonstrates.
A good way to figure out where to add the X s and angles is to draw out your frame on paper and then analyze the frame for points of compression, tension, and torque. Then mark the directions of these forces with arrows.
frame stretching-1.jpg (6 views, 10.23 KB)
Post #170007
Posted 12/8/2021 7:23:16 PM
Part Two
Another way to analyze the frame for the above characteristics is to build a model frame from light weight cardboard, Styrofoam, and/or balsa wood and then apply twisting loads and vertical/horizontal bending loads.
I personally like to model cut frames around 1/6th scale and parts from Styrofoam, glue them together, then apply forces.
There are also CAD and other programs that can be used to model structural forces. Some are very expensive, other with free trials, while others are free.
The learning curves for these programs are hundreds of hours and higher. vertigo
frame stretching-3.jpg (11 views, 273.30 KB)
Post #170013
Posted 1/25/2022 10:04:17 PM
How to Cut and Shape Foam without a CNC Foam Router or other expensive Professional Tools
Part One
So, what is the best tool to use for removing the most excess waste foam material in the least amount of time.
The Hot Wire Cutter:
The bow hot wire foam cutting tool is used for hand cutting and shaping. The commercially sold units are relatively cheap, but if you have a hand conduit bender can be made yourself for a few dollars. Sculpturers of foam usually have bow hot wire cutters that range from one foot to eight feet. Nothing removes excess waste foam like a hot wire cutter.
The attached video is the best that I have seen on the hot wire bow cutter.
www.bing.com/videos/search?q=hand+tools+for+shaping+foam&docid=608010598718269050&mid=E92ACE63FCA36DA79915E92ACE63FCA36DA79915&view=detail&FORM=VIRE
Post #170138
Posted 1/25/2022 11:37:25 PM
A simple homemade hot wire cutter and power supply that described the basics.
How sophisticated your hot wire cutter is depends on how creative you designed unit is.
Part 1-B
www.instructables.com/Hot-wire-foam-cutter/#:~:text=Hot%20Wire%20Foam%20Cutter%201%20Parts.%20The%20parts,Transformer%20and%20Dimmer%20Switch.%20...%20More%20items...%20
Post #170141
Posted 1/26/2022 10:37:26 PM
Part Two
Hot Wire Cutter Power Supply Basics
The basics of building a hot wire cutter (be it for foam, plastic, ice, or otherwise) are fairly simple. The goal here is to build a precision power controller so that you can heat up just about any hot wire cutter to the exact temperature you need it.
Nichrome Wire Hot Wire Parameters
Most foam products will require a wire capable of reaching 600°F (315°C) or higher. To heat 18 AWG Nichrome to this temperature range will require 6.5 amps. At 20 AWG, you need just over five amps. With a 26 AWG Nichrome wire, only 2.1 amps are required.
There are many ways to reach these Nichrome Wire Hot Wire Parameters using battery packs or 120V transformer fixed/variable controlled outputs. Thousands of power supply and hot wire setup plans and image files can be found online.
Post #170146
Posted 1/26/2022 11:30:04 PM
Part Three
sly
"I have tried a hot wire without much luck. Foam tends to keep melting a little after the wire passes which leaves an unpredictable cut."
A friend of mine that does a lot of work in foam for the entertainment industry informed me that controlling the tendency of the foam to keep melting after the wire passes is controlled for by:
Trial and error temperature experimentation of the wire temperature in the particular foam being used.
Using the smallest wire practical and the lowest wire temperature that cuts clean.
Most his work in done with EPS/Expanded Polystyrene and XPS/Extruded Polystyrene.
EPS/Expanded Polystyrene. This is the most common foam for hot wiring as it is strong, lightweight and cuts very easily with a hot wire or hot knife. It is usually white and is made of tiny foam bubbles. It’s often used for packaging.
XPS/Extruded Polystyrene. This is usually a denser foam that is very smooth and although the cuts are slower than EPS they are very clean and smooth. Some examples of XPS foam are Styrofoam, Owens Corning Pink board (Formular), and DOW Blueboard.
This commercial product has information on setting wire temperatures"
www.demandproducts.com/OWA/Product/Details/MAGNUM/001/-/magnum-no-gator-cord-min-24-max-108-8amp-fuse-no-longer-than-50-ext-cord
Post #170151
«««7475767778»»»
All times are GMT -5:00, Time now is 3:57am
Execution: 0.198. 13 queries. Compression Disabled.
