Vertigo's Tumbler Build
«««7273747576»»»
Posted 11/24/2020 5:51:23 PM
x
Post #168938
Posted 11/24/2020 6:23:05 PM
The importance of learning CAD (Computer Aided Design
Think about learning to use CAD with at least familiarity as the cost of admission into being able to use CNC tables (that support plasma cutting, routing, milling) and 3D printers.
This is not a skill that can be learned over night. Quite frankly it takes months and even years to become really skilled and 1-4 weeks (25-100 hours) to be somewhat functional.
Still want to experiment and learn about CAD for free.
Don't run out an buy a pricey program. If you have a computer with windows etc. there in a lot of freeware CAD programs available.
https://listoffreeware.com/best-free-cad-software-for-beginners-windows/#:~:text=LeoCAD%20is%20free%20open%20source%20CAD%20software%20for,features%20to%20satisfy%20the%20need
8 Best Free CAD Software for Beginners for Windows
"Here is a list of best free CAD software for beginners for Windows. Using these CAD software, beginners can learn and create 3D and 2D models without knowing too much about CAD. All of these software are simple and easy to understand for beginners and novice users.
These CAD software are simple, but they do not lack any important feature and also serve advanced features for professional users. To create and design a 3D model, these software provides various base models (Cuboid, Cone, Sphere, etc.) along with various sculpting tools. All of these also let you use a mouse to operate tools that make designing more simpler. Apart from sculpting tools, you also get various view orientation tools to look 3D models from all angles. Once a model gets completed, you can save or export in STL, OBJ, DAE, FBX, etc. files.
My Favorite CAD Software for Beginners for Windows:
LeoCAD is my favorite software because it provides the simplest way to create a 3D model. Plus, it is very simple to understand and to operate that could prove really beneficial for beginners. In it, you also get a lot of predefined models of various different categories which let its users to create a design just by modifying the existing models.
You can also check out lists of best free CAD Viewer, CAM Software, and CAD software for Windows.
LeoCAD is free open source CAD software for beginners. It is one of the simplest CAD software that you can find for free. The main focus of this software is to let new users quickly create a 3D model without needing to know much about CAD and 3D Modeling. At the same time, it also offers a lot of features to satisfy the need of advanced users.
In this software, you get various solid model sections like Animal, Antenna, Bar, Container, Panel, Plant, Vehicle, Wedge, etc. In each section, you get various predefined 3D shapes related to that section. You can easily drag and drop shapes to the canvas and join them through mouse to quickly create a 3D structure. Along with shapes, a Colors window is also present in it to quickly assign different colors to different models.
This software stores all the steps performed during 3D model creation, which you can access from its Timeline Section. Using Timeline Section, you can also move to any previous step or to the next step of the model creation process. This helps novice users to easily produce a design. Besides this, simple tools such as movement, snap, rotation snap, relative transformation, etc. to change model orientation, model position, model angle, etc., are also present in the toolbar. After creating a model, you can easily export the model as 3D Studio, BrickLink, Collada, CSV, HTML, POV_Ray, etc. formats.
In general, it is one of the easiest software to create 3D models for beginners.
Go to their website for other free CAD software programs.
k-3D
3D Slash
Wings3D
3D Builder
FreeCAD
Strata Design 3D
LibreCAD
Post #168940
Posted 11/27/2020 4:57:29 PM
Received an email today, "All that computer stuff is great but most people can't afford CNC programs and cutting and printing machines. I want to build a batmobile but I don't have very much money for the cnc tools. Looks like batmobile building required technology is turning this into a rich guy project."
vertigo, "You could always go old school. Scaling squares, image enlargement projectors, and pantographs."
Part Four First posted 12-20-2017
3D Pantographs
reality.
Why?
Cost:60,000 plus.
of a router.
scale part in 3D.
plans/Instructions
woodgears.ca/pantograph
Post #168952
Posted 11/29/2020 10:23:35 PM
More and more, custom and short run car model makers are using 3D printers to produce 1:6 and larger models.
Complete models, dioramas, parts, assemblies, etc.
Post #168961
Posted 12/3/2020 5:44:37 PM
All 3D Printing Filaments Types Explained: Detailed Guide
How to choose the filament for your next 3D printing project.
Joseph Flynt
by Joseph Flynt
Posted on
August 24, 2019
https://3dinsider.com/3d-printing-filaments-types/
Go to this website for everything you need to know for choosing the right filament for your 3D printer projects.
'Of all 3D printing technologies, Fused Deposition Modelling (FDM) has taken the lead in terms of popularity. FDM printers are cheap, easy to learn, and can be used with a wide range of different filament materials. In fact, there are so many different filaments available today that picking the right one for your project may seem overwhelming.
In this article, we go through even single one of the common FDM filaments, highlight their strengths and weaknesses, and discuss their best applications. We’ll start with the most popular ones and work out way down towards the more obscure and unusual alternatives.
There are a lot of options for 3D printing filaments out there."
Post #168977
Posted 12/4/2020 5:34:50 PM
Placed a copy of this post here for anyone planning to, and/or, actually building a Bat Vehicle.
Here is an online 3D printer filament calculator.
http://tools.3deee.ch/f_calculator
3DEEE FILAMENT CALCULATOR
Volume Length Weight
Do you know, how many meters of 3d printing filament do you need for your next print?
Do you know, what volume your can print with a given length or weight of 3d printing filament?
Do you know, what weight of 3d printing filament you need on your spool, to finish your next print successful?
With this calculator, you can convert the length of 3d printing filament into the weight of the 3d printing filament and the volume of the 3d printed model. You can also upload an STL-file* to determinate these values.
As for Material Presetting we have PLA, PLA/PHA, ABS, PETG, TPU, PA6 and PA12. But you can insert your very own, custom material and also use other density settings for the calculation.
Post #168982
Posted 12/9/2020 6:45:46 PM
Go to 3dinsider.com/wax-3d-printing/ to read complete article
3D Printing with Wax: The Process of Lost Wax Casting
Joseph Flynt
by Joseph Flynt
Posted on
July 31, 2019
"We know all about additive manufacturing by 3D printing. A filament is molten by a hot extruder and deposited on a print bed, and layers are built one by one until the design has been completed. It’s a direct, single-step procedure that produces the model in your desired material quickly.
However, there are also other, more indirect methods of additive manufacturing. One of these methods is called lost wax casting – a process that uses wax to create molds, which can then be used to create highly detailed designs out of molten metal.
Lost wax casting is a very old technique and has been used even before 3D printers came into the picture. Through this technique, a mold can be created from a prototype that was made using wax. For traditional jewelry makers, lost wax casting is a highly useful method for producing a high volume of custom pieces. It is especially suitable for replicating very detailed designs quickly and accurately.
In lost wax casting, a mold is built about an initial prototype made of wax. Before 3D printing, artisanal craftsmen made these prototypes by hand by painstakingly carving details into a solid wax block. A negative mold is then built around this prototype using a more heat-stable material.
The wax prototype can then be easily melted away, leaving a negative mold with a cavity that accurately mimics the prototype. Since the mold itself is heat-stable, it can be used to create pieces out of sturdier materials such as molten metal.
In modern times, the method of lost wax casting isn’t really all that different. However, 3D printing technology has made it easier and faster to create a wax prototype. There are now several wax-like filaments that can be used with FDM printers and can be polished before being used to create negative molds.
1. Choose a design
2. Print the design using wax filament
3. Create a negative mold
4. Use the mold to create metal products
The best wax filaments for lost wax casting
1. Print2Cast Wax Filament
2. PolyMaker PolyCast Filament
3. PORO-Lay Mold-Lay 3D Printing Filament
Advantages of lost wax casting
1. Does not require a lot of skill
If your goal is to make a metal object with a complex design, it’s much easier to do lost wax casting than to resort to more traditional ways of working with metal.
2. Cheap
Of course, not everything has to be done the old-fashioned way. You can turn to technology, such as metal laser sintering, to produce highly complex metal objects. The downside is these types of equipment are very expensive. If you already have a 3D printer on hand, why not leverage of its capabilities to make your metal models cheaper?
Final thoughts
Lost wax casting is a very old technique, and marrying it with today’s 3D printing technology has really opened up a lot of possibilities."
Post #169022
Posted 12/10/2020 7:10:20 PM
spidey4fun's posting about using a powered hacksaw has inspired me to post about it's usefulness.
The power driven horizontal reciprocating saw concept goes back for several thousand years.
Of course, power in the old days was generate from mostly water wheels, etc.
The usual primary principal behind the reciprocating power saw is the conversion of rotary motion into linear motion. This type of saw has been used to cut wood, metal, stone, etc.
For anyone needing an inexpensive power metal cutting saw this is it. Many have been built for only a few dollars if that.
I have attached a set of common measured plans and a second image that is so simple to understand it can be described as a pictorial blueprint. This type of homemade saw is commonly found through out the world.
Online, you can find thousands of images and plans.
Ebay often has several offered for little money.
powered hacksaw-1.jpg (10 views, 77.28 KB)
powered hacksaw-2.jpg (6 views, 133.19 KB)
Post #169031
Posted 12/10/2020 7:20:27 PM
A metal cutting band saw is what most use today.
Post #169033
Posted 12/10/2020 9:16:45 PM
Posts: 506, Visits: 8,329
Depends on your budget. Old school $100 mechanical hacksaw works for me. And now it auto shuts off when finished cutting.
Post #169034
«««7273747576»»»
All times are GMT -5:00, Time now is 6:42am
Execution: 0.266. 10 queries. Compression Disabled.
