Last Login: Yesterday @ 8:46:32 PM
Visits: 7,114
It's going to be SOOOOO heavy.
www.spidey4fun.ncable.net.au
Last Login: 2/14/2019 6:26:49 PM
Visits: 3,198
hey,
towman, War Machine, slysnake, and spidey4fun
Thanks for the kind words. vertigo
Last Login: Yesterday @ 7:31:49 PM
Visits: 2,001
It's going to be SOOOOO heavy . Yep, gonna need a strong motor and suspension. But I think Vert is already planning on that.
Plus...……. It will be bulletproof!!
Visits: 3,198
sly,
"I notice you said test fire cannons. Will they be live ammo, sim fire, or compressed air?"
Cannons will not be firing live (projectile) ammo.
Black powder blank ammo, maybe?
3000 psi compressed air high strength reservoir with dump valves a possibility.
When you say "sim fire" what does that mean to you?
What weapons simulated fire devices do you know about that are possibilities?
Visits: 2,001
I plan to use sim fire guns on my DOJ build. They fire using gas and electronic ignitions systems. Many have used them on their '89 builds. Here's an example website. http://www.replicasandmodels.com/simfire.html
There are kits for the electronics that allow you to build your own gun, which is the way I will go. Also, for the defensive array I plan to use compressed air to fire silver confetti to simulate chaff. Should look cool in parades.
Visits: 3,198
sly
"I plan to use sim fire guns on my DOJ build. They fire using gas and electronic ignitions systems. Many have used them on their '89 builds. Here's an example website. http://www.replicasandmodels.com/simfire.html
There are kits for the electronics that allow you to build your own gun, which is the way I will go. Also, for the defensive array I plan to use compressed air to fire silver confetti to simulate chaff. Should look cool in parades."
Thanks for the information and insights. vertigo
Visits: 3,198
Came across this photo-image that depicts how the BatPod was stored in the Tumbler for emergency use.
This is the only detailed image I have seen on this subject.
Very revealing information.
Visits: 3,198
Here is a website that has information on building air cannons that may be modified to Bat Vehicle building.
Air cannons are pneumatic launchers that fire a projectile or create sound a sound wave by means of suddenly releasing compressed air pressure from a high pressure chamber.
www.aircannonplans.com
Visits: 3,198
Placed a copy of this post here for anyone planning to and/or actually building a bat Vehicle.
Here is my favorites for use with dura-blocks. I order off Amazon
Dura-Gold Premium - 40-600 Grit Gold - Longboard Continuous Roll 20 Yards long by 2-3/4" wide PSA Self Adhesive Sticky back Longboard Sandpaper for Automotive and Woodworking by Dura-Gold
Sizes: 40-600 Grit
40-Grit
80-Grit
120-Grit
150-Grit
180-Grit
220-Grit
320-Grit
400-Grit
600-Grit
40-600 Grit DURA-GOLD Premium Gold LONGBOARD FILE SANDPAPER 2 3/4" x 20 Yard PSA Roll
Shaping Body Filler, Removing Paint, Rough Feather Edging, Primer/Metal Sanding
Dura-Gold Sandpaper delivers a fast, exceptionally long lasting cut that increases your productivity.
Used on: Pneumatic Air File Shoes, Hand Sanding Blocks, Firm or Flexible Longboard File Boards.
Provides Exceptional Sanding Performance, so you can get the job done fast, saving you time and money!
$17.96 & FREE shipping on orders over $25.00.
Visits: 3,198
Placed a copy of this post here for anyone planning to and/or building a Bat Vehicle.
Used V-drives can be found in boat salvage yards that have used parts and junked performance boats.
Makers of new v-drives:
Menkens
Menkens 2000
Aero Marine - Thourobred
Ace - Champion
Glenwood
Crusader
Hallcraft
Argo Marine (www.argomarine.com) based in Austrailia
Milner (these have been used in Tumbler replicas and in movie cars)
