Vertigo's Tumbler Build
«««5152535455
Posted 6/2/2018 6:38:51 PM
Last Login: Yesterday @ 3:12:32 PM
Posts: 639, Visits: 1,312
Same I have then
Post #160635
Posted 6/2/2018 8:40:30 PM
Last Login: Today @ 6:21:37 PM
Posts: 1,987, Visits: 2,866
Placed a copy of this post here for the benefit of anyone planning to build and/or actually building a DOJ/Justice League Bat Vehicle.
Received an email asking what tools did I use to strip down my DOJ/Justice League Batmobile donor vehicle.
Heavy leather welding gloves. (razor sharp edges are everywhere when cutting donor sheet metal.)
Dewalt 20 volt battery tools.
Compact reciprocating saw and around 40 bi-metal blades
1/4 " drill driver with screwdriver set that includes torx tips
3/8 " Impact driver (out standing tool - removing bolts nuts fasteners took about 1% of conventional hand wrench and ratchet time.)
A good size mirror attached to a length of plastic pipe.
English and Metric sockets with conventional and deep-well sockets
Crowbar and a small pry bar
Utility blade knife (lots of insulation and plastic sheeting)
NOTE: My Dodge 3500 was built in a Mexico plant and most every fastener, bolt, and nut is metric.
Post #160640
Posted 6/8/2018 8:16:17 PM
Use to use plasma to cut most flat plates and parts for my Tumbler but for the past year I have done most of this cutting with metal cutting circular saws.
DEWALT DCS373P2 20V MAX Lithium Ion Metal Cutting Circular Saw Kit
Powerful 460 MWO, 3700 rpm motor
Bright LED Light with 20 second delay after trigger release
20V MAX Lithium Ion 5.0 AH battery
SIGHT-LINE Window provides for a clear view of the material
$339.95 & FREE Shipping at Amazon
If you already have a 20 volt tool with charger and battery you can get the bare tool
metal cutting circular saw for 191.00
Metal cutting circular saws cost 1-2.00 per foot to cut 1/8" - 1/4" thick plate.
Very efficient tool for cutting plates and flats vertigo
Post #160665
«««5152535455
All times are GMT -5:00, Time now is 9:19pm
Execution: 0.062. 11 queries. Compression Disabled.
