Posted 8/26/2013 8:59:09 PM |
Visits: 8,993
The motor used on the real bikes is a Honda CRF450X with electric start. It is a single cylinder motor with left hand sprocket drive.
Posted 8/26/2013 9:09:26 PM |
Visits: 8,329
Yes you are correct on the motor as I mentioned on the post above yours... or I could go ELECTRIC!!! http://www.goldenmotor.com/
Posted 8/28/2013 1:21:17 AM |
Visits: 8,329
Im doing some maths and would like to know the weight of the Pod. Can someone who owns a Parker Bros. Pod throw it on some scales and get its weight?
Thanks
Brad.
Posted 8/30/2013 5:39:00 AM |
Visits: 8,329
Front wheel hub, axle and disk.
Now to drill a hole through the square axle and fit some bearings.
Brad.
Posted 8/30/2013 11:18:05 PM |
Visits: 8,993
spidey4fun (8/28/2013) Im doing some maths and would like to know the weight of the Pod. Can someone who owns a Parker Bros. Pod throw it on some scales and get its weight?
Thanks Brad.My Bat Pod with no motor weighs as much as my big Harley if not more.
Posted 8/31/2013 2:37:50 AM |
Visits: 8,329
umm.. ok.. what model Harley? Ill look up its weight... Or could you be a little more specific?
Brad.
Posted 9/1/2013 11:22:38 PM |
Visits: 8,329
Another question for you Pod owners. What thickness steel is the frame made from? Looking to make mine as light as possible.
Brad.
Posted 9/3/2013 10:57:18 PM |
Visits: 8,329
I've made some inquiries on steel pipe and redrawn the frame of the Pod to match. I hadn't noticed the way the front shock was done before. Seems there's another arm below the shock and the support that comes off the frame must actually rotate. I've used a couple of Shaggy's parts from his sketch-up and they are represented in green.
Brad.
Posted 9/9/2013 10:17:02 AM |
Visits: 8,329
Been doing a ton of research and thinking I'll go electric.
I intend to use it as a functional display piece for Comic cons and other shows. I'll gear it so it's top speed is reduced and lower end has more go.
Brad.
Posted 9/11/2013 3:25:53 AM |
Visits: 8,329
I made the back part of the frame a little longer as it didn't fit my 6 foot model. There wasn't enough room between the knee rests and the foot pegs.
Brad.
