Posted 6/10/2012 1:06:34 PM |
Last Login: 5/1/2018 2:10:01 PM
Visits: 175
So i've been doing some research on building a car body since i want to attempt to build my own 89' Batmobile. I came across a very good plan for 'Building a Lamborghini Countach' we can simply learn from it and build our own desired car body. I just wanted to share this awesome file with you guys
Here it is: http://kit-car.org/Files/lambo/Countach/PLANS-Lamborghini-Countach.PDF
How awesome is it that I was born in 1989
Posted 6/11/2012 5:03:34 PM |
Visits: 175
I was wondering what the exact dimensions for the body are, I found 3 different ones on the website
Posted 6/11/2012 9:48:44 PM |
Visits: 3,119
Check this page
it won't be exact but should give you some idea as to what you are dealing with.
none of the kits are the same anyways
http://www.chickslovethecar.com/KeatonBlueprints.aspx
look at all the files
good luck
later dude...
333 HALF EVIL
Posted 6/13/2012 10:36:49 AM |
Visits: 175
Posted 7/24/2012 1:30:13 PM |
Last Login: 4/14/2024 1:07:55 PM
Visits: 1,032
Neat idea, mostly sounds useful if someone is going to make their own molds.
The will to act.
Posted 8/13/2012 1:51:32 PM |
Visits: 8,993
Something you might want to think about... With the availability and the pricing of a full build kit, I couldn’t see why anyone would want to build a body from scratch? There have been several people have tried to replicate the 66 Batmobile for the past 20 years and they still have missed the mark. Urethane foam is extremely expensive along with a good quality resin. By the time you build the plug, glass it in fill it with filler sand the whole thing out not including the labor involved you would most likely paid more than you would have to buy a Kit. Then again, if that is the thing you really like to do then more power to you…
Posted 8/14/2012 9:26:12 AM |
Last Login: 10/3/2023 11:25:43 AM
Visits: 75
Hey I have done all the hard work... 20 hours worth... lol But... I have a set of Patters for the Keaton build.. I just needed some reals measurements on the car.. but if not my plans are very close with out it.. so if anyone needs a copy let me know...
Cleve DuBois
Posted 8/14/2012 9:42:51 AM |
Visits: 75
But Yeah Kevin is right it's alot of work and if you have the money the kit is the way to go... I'm just too cheap!
Cleve DuBois
Posted 8/22/2013 1:26:56 PM |
Last Login: 8/22/2013 1:12:03 PM
Visits: 1
Hi everyone, this is my first post. I live in New Mexico, and I am currently drawing a full set of plans for the Lamborghini Countach. The plans are very detailed. Every part is blueprinted. I have the rear wing, chin spoiler, front bumper, engine deck lid, air intake scoops, and rear tail light panel finished. All dimension are in these prints.
I can send pics by email
If interested email.......fayetteleake@gmail.com
Take care
Posted 11/9/2013 9:48:23 PM |
The cake is a lie.
Visits: 513
Urethane foam can get expensive depending on weight/density and the amount needed. I'd recommend getting expanding urethane foam that is about 16 lb. in weight as it's less pricey and easier to obtain than the comparable foam blocks. Many marine stores that too carry fiberglass supplies should have it. For large, primarily flat surface areas -sides of rear fenders, tops of front fenders, top of bonnet, canopy top etc- Formica would do just fine as it's pliable, relatively cheap and allows the builder/fabricator to save the foam for areas that actually need to be 'sculpted'.
Hopefully, this will be somewhat helpful.
