No Mercy build by BWD
«««23456»»»
No Mercy build by BWD Expand / Collapse
Posted 8/20/2012 12:32:31 AM
Posts: 5,397, Visits: 4,897
Good I'm glad I could be of help. I plan on using the towbar on the 89 too. The skid plate is already set.These are the side pieces that needed to be fiberglassed to the batwings. After fiberglassing them on it became apparent they were made wrong. The angle needed to be changed to an angle that would allow for the arc. These two side intakes rotate up as the car speeds up.
Post #87623
Posted 8/20/2012 12:42:06 AM
Here are the scissors doors up. After a lot of adjusting they shut pretty nice
Post #87625
Posted 8/20/2012 12:47:16 AM
Here were a couple ideas on the wheels we might use.
Post #87626
Posted 8/20/2012 12:58:56 AM
Here are two pics of the chassis under the body showing the body is off about 3/4 of an inch. This part of straightening the body to the chassis is so important. Once its set you don't want to have come back to it later
r
Post #87627
Posted 8/20/2012 1:03:55 AM
The front trunk lid frame is a crooked so we decided to redo this frame
Post #87628
Posted 9/3/2012 6:46:40 PM
Getting a little into the fiberglass molding thing. Still got a ways to go but its pretty fun. Here's part of the Lambo fiberglass headlight assembly I bought on ebay. The goal is to duplicate this part for the two Lambos I'm building.
Post #87847
Posted 9/3/2012 6:51:16 PM
The full headlight assembly is pretty intense.Have to fix that chip before we start
Post #87848
Posted 9/3/2012 6:53:45 PM
Here is the mold I made off of those real buckets. Man I was stresssed about them popping off.
Post #87849
Posted 9/3/2012 6:58:05 PM
was really happy with the details of the molds. I even tried to copy the color that Lambo uses for their fiberglass pieces.
Post #87850
Posted 9/3/2012 7:11:40 PM
Here is the Lambo Coupe with the Corvette wheels. You can see we really need to extend the axles. On the other set of rims the axles needed to be extended 7 1/2 inches on each side. I want to hold off the axle extension until we are 100% sure on the rims,
Post #87851
«««23456»»»
All times are GMT -5:00, Time now is 3:55am
Execution: 0.328. 11 queries. Compression Disabled.
